Old 02-08-2014, 11:45 AM
68bird400HO's Avatar
Originally Posted by starlightblack View Post
a 1971 Trans Am engine date May 20, 1970?
Yup. These were the 455 blocks carried over from the end of the 1970 model run and used up in the 71 HO cars. There were actually three casting numbers for the 1971 455HOs. The first was 9799140 which was the 1970 carry over. Then 483677 was used on the early 71 455 blocks (castings from Aug 70 or maybe earlier). Then it switch again to 485428 which was your later 71 455 block casting used through 1974 (except SD).
The Following 2 Users Say Thank You to 68bird400HO For This Useful Post:
Old 02-09-2014, 10:45 AM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
Yes that's Jeff's stuff. Right down the highway from here....
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
Old 02-10-2014, 10:48 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
4-speed Lloyd? WW5?
M22 - yep, WW5 - nope.
The original owner - Skip Barooby - (who I've spoken with over the phone) special ordered that GTO with every "WW5" option except two - the Formula steering wheel and an in-dash tach. Dunno about the steering wheel, but he preferred the hood tach. He ordered the car with gauges and clock, and had the dealer install the hood tach (and the Judge rear deck spoiler) before he took delivery.
Regards,
"455HO" Lloyd
Old 02-10-2014, 10:55 AM
Lloyd-TX's Avatar
Here are the window sticker and the (pre-PHS) invoice.
Name:	Sundance GTO HO window sticker w-o VIN.jpg
ID:	352522   Click image for larger version
Name:	72 HO GTO Sundance Invoice cropped no VIN.jpg
Regards,
"455HO" Lloyd
Old 02-10-2014, 01:10 PM
pggto's Avatar
pggto pggto is offline
I believe those engines belong to Uncle Judge
Old 02-10-2014, 02:00 PM
Lloyd-TX's Avatar
Red face
Yep - they do.
Regards,
"455HO" Lloyd
