Old 10-29-2019, 08:28 PM
694.1 694.1 is offline
Default 1955-1958 Oil pumps & rebuilding
These pumps are not available new, are hard to find & apparently the newer V8 pumps will not fit.
I have a pump on the way home from Egge in CA and the cost was $145 to be overhauled.
A dissection will be in order and I can post up a full report.. Maybe you guys know, I have a spare core...Would new V8 guts fit in the early housing? Should everything meet spec, this may be a viable alternative.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-30-2019, 12:36 AM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Yes, guts from a newer pump will fit. I ran Melling M54D guts in my '57 347 daily driven for about 5 years. Later pump to block gasket will not fit. You'll have to make one from very thin gasket stock available at FLAPS. Here is an old thread that goes into detail on this subject. http://forums.maxperformanceinc.com/...d.php?t=696541
Old 10-31-2019, 05:15 PM
Thanks for posting up that thread, it is pretty much the last word!
It looks like I spent more than I needed to...
7th Firebird
57 Starchief
Old 11-06-2019, 11:11 PM
Got my pump back from Egge, ran $145.
They charged me $26 to ship it back, funny that it only cost $13 to ship it to them. The extra cost must have been for that warm CA sunshine in the box?
Included was this Cert from testing.
Looks like we are good to go!
7th Firebird
57 Starchief
Old 12-12-2019, 08:13 PM
I picked up an NOS pump the other day & went through it to clean it up, inspect it and to de-burr everything . Attached are a couple of photos.
The first shows some high spots that I took down with a very fine stone. Interesting, an example of blurbs that are highlighted..
The second shows a spiral like cut on the bottom of the driven gear. My guess is that this is not an accident but a grove to help keep the bottom of the gear lubed?
ID:	526596   Click image for larger version
7th Firebird
57 Starchief
Old 12-12-2019, 09:37 PM
I don't remember the details, but there was talk MANY years ago on this forum about direction the driven gear should be installed on the shaft. Maybe one end was flat and the other end has kind of a bit of a cone cut into it where it met the shaft. I'll see if I can find it.
Old 12-29-2019, 01:09 AM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
Last spring I put Melling guts in my stock 347 pump, including the relief valve. Now my oil pressure is between 35 and 60, depending on temp. Much better! Photo shows the difference in thickness of cover. Melling is at least 3 times thicker.
Roll around in the excitement
