Old 08-18-2010, 11:00 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default Pontiac Parts
Some Pontiac Parts that I have. Pictures taken upon request. PAYPAL Preferred. Will trade/ trade with money for a set of 1.5/1.52 roller rockers.
All shipping is paid by you.
For local Pick-up.
1962 389 Complete from intake carb to pan, no exhaust manifolds.Best offer.
Heads and block need to be decked. As new head gasket is still leaking for low spots.
Heads Casting #538177 will remove and separate.
WILL PART OUT ENGINE PARTS if you only need a certain thing
2BBL Rochester carb from above engine. Good shape, probably needs a rebuild. Ran ok and inside looked good when I had to check jets. B/O$
67 Tempest Column shift automatic steering column donor for parts 25$
Will Ship
1962 Pontiac Rocker arms, pivots and nuts (Used) 40$
1962 Pontiac Points Distributor Worked when pulled a month ago. Needs points. New Cap and Rotor 40$
Black Wrinkle finish Vacuum canister with Gauge and mounting hardware 30$
Energy Suspension 3.1108R Trans mount missing bolts and washers NEW. 10$
Energy Suspension 9.9101G Bump Stops NIB. 5$
ARP 190-2201 PP Bolts. Did not fit. NEW. 8$
ARP PRO 290-2802 Flywheel bolts, Installed but found out that they were too high, then removed. Engine was never started with these bolts in car. 20$
2 Thrush Turbo Mufflers 17696. Had them one for 2 months, then went to welded mufflers. 2.5 in and out offset/offset. I have turn downs tack welded on that I can remove if you want. Great Condition. 45$ or B/O
2 1967 Tempest Drum Hubs in great shape 15$ each
2 1967 Tempest Brake Drums 100-150 miles on them. B/O.
Email with questions.
david.dixey@gmail.com
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 08-18-2010, 08:10 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Do you have pics of the brake parts, I have a 67 GTO, should be the same. I am disc front drum rear. Send pics to billcaprio@optonline.net
Old 08-18-2010, 09:30 PM
The drums and hubs are for the front.
The Burb Files
Old 08-31-2010, 02:06 PM
The Burb Files
Old 08-21-2012, 11:21 AM
What I have left:
2BBL Rochester carb B/O$
67 Tempest Column shift automatic steering column donor for parts 25$ OBO
2 Thrush Welded Mufflers 2.5" offset/offset the flanges are a tad hacked but very usable.
CS130 140A 1-wire alternator straight up ears. 125$
The Burb Files
Old 03-18-2013, 01:47 PM
What I have left:
MULTIPLE 2BBL Rochester carb B/O$
The Burb Files
Old 04-17-2013, 09:42 AM
I have to start moving some of this stuff.. BEST OFFERS PLUS THE RIDE!!!
Or come and pick it up!!!
PayPal is preferred.
The Burb Files
Old 04-17-2013, 09:57 AM
ITSBACK's Avatar
PM sent
Old 04-17-2013, 10:11 AM
What I have left..
The Burb Files
