Old 11-17-2012, 08:20 PM
geebjen's Avatar
geebjen geebjen is offline
Default Rebuildable 455 package
Here's a good package deal for someone looking to build a 455.
71 YC 455 from a GrandVille with 66 heads.
72 Intake
6x-4 Heads
17039253 Q-Jet Carb which needs rebuild.
All for $625.
Here's some more detail on the engine. I pulled it from the GrandVille with about 110k miles and ran it in a 77 trans/am for a couple years until it started making a pretty bad knock. Opened it up and found the #2 rod bearing gone and the #1 almost gone. However, I measured the journal and it's still at 2.24 so it should clean up fine at .020 under. I presume the bores are std since it doesn't appear to ever have been rebuilt. I'll refund your money if the crank or block aren't rebuildable at .030 under/over max.
Any questions, just send me a PM or e-mail.
ID:	303333   Click image for larger version
ID:	303334   Click image for larger version
Old 11-17-2012, 08:23 PM
geebjen's Avatar
Default Forgot the heads..
Oh, and here's a couple pics of the heads.
ID:	303337   Click image for larger version
Old 11-27-2012, 07:23 PM
geebjen's Avatar
Default Still Available..
Still available.....will answer any questions either here in the forum or via PM or e-mail.
Old 12-04-2012, 09:49 AM
geebjen's Avatar
Default Price reducded...
Price reduced to $575...........
Old 12-19-2012, 01:59 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Date code on the block?
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 12-19-2012, 12:57 PM
geebjen's Avatar
Default Here's the code
I can't really figure out the first digit because the casting isn't very clean.
Old 12-20-2012, 04:40 PM
geebjen's Avatar
Default Intake changed to a 71
I had to use the '72 intake so the intake included is now a '71 intake.
I'll also lower the price to $525....
Steve
Old 12-20-2012, 07:02 PM
Block is cast B251.
The original YE in one of my '71's was cast the same day.
Old 01-06-2013, 10:54 PM
geebjen's Avatar
Default Another price reduction...
Taking it down to $500......eventually someone will want it.
Old 01-11-2013, 09:50 AM
geebjen's Avatar
$475 anyone?
Old 02-07-2013, 03:53 AM
RACER X RACER X is offline
Default 455
Do you still have the 455? I am in need of a block as mine has cracked. Is your block factory drilled and tapped for four bolt mains?
Old 02-07-2013, 08:03 AM
geebjen's Avatar
Default Yes, still have it.
Yes, I still have it and it is drilled and tapped for 4-bolt mains if I'm remembering how that worked correctly. Here are a couple more pics which show the 4 bolt main drilling and tapping for you to see.
Steve
ID:	312363   Click image for larger version
Old 02-07-2013, 12:41 PM
Default 455
I am interested in the block n dont need anything else. I would like to make a deal with you. If you could tear it down and take to your closest machine shop and have plugs pulled , degreased, and magged for cracks then i would buy it from u for $400. i saw where you would give money back if i checked for cracks, but the problem is that i bought a block last month n found out it was cracked. Yes i got my money back from the seller, but it cost me $123 for the machine shop bill, and i still have no block. What do you think?
Old 02-07-2013, 12:59 PM
geebjen's Avatar
Default Thanks
I appreciate the offer, but I think I'll pass. I'd rather sell it whole.
Steve
Old 02-09-2013, 10:48 AM
71SportRagtop's Avatar
71SportRagtop 71SportRagtop is offline
Will you ship?
I'm interested in the motor but I live in PA just north of Philly and honestly don't feel like driving a 5-600 mile round trip.
Greg
68 Firebird Verdoro Green
428, 6X-4 heads, Comp XE284 cam
Muncie 4 speed
3:73 rear
Old 02-09-2013, 11:18 AM
geebjen's Avatar
Default How quick do you need it?
I don't think I'd ship it, but I have to make a trip to the Wilkes-Barre area with my truck in a month or two. If you could wait that long I could meet you in that area somewhere.
Old 02-09-2013, 03:58 PM
I have a vacation home in the Pocono mountains of PA, about 1/2 hour from Wilkes-Barre. I'd be up for a meet. Hit me up when you're headed that way and hopefully we can work it out. I have nothing but time as I have a running 400 in my Firebird. This motor would be built over time anyway.
Thanks, Greg
Greg
Muncie 4 speed
3:73 rear
Old 02-09-2013, 04:57 PM
geebjen's Avatar
Default Ok, will do.
Ok, I'll be in touch when I'm ready.
Old 04-15-2013, 11:16 PM
geebjen's Avatar
Default PM Sent
71SportRagtop, I sent you a PM about meeting with the engine...
