Cam thoughts
This is the sft that my builder has chosen with help from his guy at Bullet. It's to replace my solid roller that was damaged.
250/256 606/607 installed at 104 Going in my 472 stroker, being dynoed Monday.
69 Firebird 472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123 |
The Following User Says Thank You to 461-69bird For This Useful Post: | ||
Nice.... I guess you'll find out Monday if they did a good job on the cam selection.
Good luck with the dyno session. |
Are the KRE heads stock or ported? Stan
10.75 and the heads, 85cc d ports are 300
Sounds like a nice build! Good luck with the dyno session.
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
Sounds kind of mild to me. My first roller 455 E head motor had a 259/262 @ 0.050 UD lobes and was fairly streetable, not at idle but on the rollers it would even pass emissions on the sniffer!
I'm not chasing every last hp this time, just want a low maintenance bracket engine that I can drive on the street.
Got ya thought it was a SR. I ran an UD 288/292 255/259 @ 0.050 SFT in my RAIV 400. Pretty lumpy in a 400 least vacuum of any cam I had in it.
I am all in for a low maintenance motor too!
Is that lift with 1.5 rockers ?
I ran a 455 at 11.4:1 static CR with stock 16 D-ports and an Ultradyne 255/263 duration @0.050" solid flat tappet and the car went 11.4 in the 1/4 as a point of reference.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
Well seeing as your 1.65 rockers will add 3 to 4 more degrees over the nose of the cam and considering what you have for intake flow with those heads I would say that you will have no less then 550 Hp.
More might be on tap depending on the manifold your running . Will the motor have headers?
Maybe start with 1.5:1 on the Exhaust? And stay with it.
No not buying anymore parts for this, it will have to do with what I've got
