Old 07-30-2023, 06:20 PM
Tim Corcoran's Avatar
Default 455 Destroyed at Norwalk
I was at Norwalk in my 65 LeMans and during my first time run on Saturday in the Pro class about 400 feet from the 1/4 mark I heard a big WHAM and everything went silent. I have included some photos. Kind of a chicken and egg situation tell me what you think went first the crack in the number 3 main web or the crank.
ID:	617059   Click image for larger version
ID:	617060   Click image for larger version
ID:	617061   Click image for larger version
ID:	617062   Click image for larger version
Tim Corcoran
Old 07-30-2023, 06:33 PM
Default 455 gives up the ghost
More pictures
Last year towed the car all the way from North Carolina and took out the trans on my first time run. This year it was my engine, something evil about Norwalk for me.
ID:	617065   Click image for larger version
Tim Corcoran
Old 07-30-2023, 06:35 PM
You certainly don't do things by halves!
Old 07-30-2023, 07:10 PM
Half-Inch Stud's Avatar
Seems the crank broke 1st, in the rod throw underarm, then then block and CYL walls.
Old 07-30-2023, 07:14 PM
sdbob sdbob is offline
Sorry for the problem. I'd be curious what others say. I had a friend in a 66 GTO take the front out of his 455 block at Norwalk. I think it was a mid 10 sec car( he has since passed). Crank and block were used from a ... I thought balancer ,or crank and block were used with nitrous previously by the person he bought parts from. I have a stk 455 crank in my SD. Its seen 6400 couple times in the water. I'm not making power you are though.
Old 07-30-2023, 07:17 PM
WOW!
Sorry to see all of that!
Was that a stock crank?
I wonder about the hole(s) in the bore. May have locked it up and broke everything else?
Need to see if you can find the original beginning of a crack in the crank, bore or main web.
Old 07-30-2023, 07:20 PM
ID67goat's Avatar
ID67goat ID67goat is offline
This is what I was thinking also….
Sorry to see this as it looks like you put some nice parts in this engine (main caps, lifter bore brace etc.)
What crank did you have in there?
Old 07-30-2023, 07:53 PM
4.25 Ohio cast crank, when I put this engine together years ago the forgings weren't available yet. I sure wish I would have upgraded to a forged unit. The thing is, I had a warning car slowed down about .4 from what is should have been running and oil pressure seemed a little sluggish the first two runs before the one when it broke. All the bearings look good so it wasn't starving for oil.
Tim Corcoran
Old 07-30-2023, 08:09 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
Cast crank probably let go first
I personally didn’t like the Ohio cast cranks
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
The Following 2 Users Say Thank You to Richie Hoffman For This Useful Post:
Old 07-30-2023, 10:14 PM
Tom Vaught's Avatar
Boost Engineer
X2 on that.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 07-30-2023, 10:15 PM
chiefbigb chiefbigb is offline
Bright side you have a clean slate to work off of. Are the heads damaged much
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 07-30-2023, 11:23 PM
Heads are fine already bought a 71 400 block from the swap meet at Norwalk going to build a 400 stroker. Block is at the machine shop getting sonic checked so I know how far I can safely bore it out. then I will get a rotating assembly from Butler.
Tim Corcoran
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post:
Old 07-31-2023, 06:00 AM
steve25 steve25 is offline
I think the block let go first.
That main web crack runs right along the oil passage that runs from the oil feed hole from that main up to the Cam Bearing .
If it was not that and the Crank did let go first, then to me since the Crank let go in its center this is a clear cut example of why at a certain point the Crank needs all 8 counter weights, not just 6!
Old 07-31-2023, 07:41 AM
mgarblik mgarblik is offline
I would tend to agree with that. We cracked 3 455 blocks in a similar fashion but not catastrophic damage because the crankshaft didn't break. We broke all 3 through the #2 main right up to the cam bore like yours. I would recommend a fully counterweighted crank of course and a slight overbalance next go. We had good luck with 2%. This is one reason the IA 2 blocks have a downsized oil feed hole from the cam tunnel to the mains. That adds a little material in that critical area. Also the solid lifter area helps hold everything together. Do you happen to know your bob weight off hand/? Curious how heavy the assembly was. Sorry about all the damage you have there.
Old 07-31-2023, 08:00 AM
Don 79 TA Don 79 TA is offline
good gawd those photos hurt so much to look at, especially now at this high costs of parts/labor
the price of a new engine now is just insane
i'd love another engine, but at my age, and use of the car, and then seeing the $$ needed, OMG
good luck, but...... now you can build something bigger, stronger, faster lol
that was my moto when i was doing my jetski engines lol
sounds like you did get some good life out of your setup, so thats good
Old 07-31-2023, 08:13 AM
Jay S's Avatar
Jay S Jay S is offline
That is a bummer Tim. At least it happened somewhere that you didn’t end up going for a ride and it sounds like it was all contained in the engine, and you saved the top end.
From the photos the block looks like a clean break that just happened. The crack on the crank at the front side of the throw looks like it has some fatigue cracks starting. Those overseas cast cranks don’t have a great reputation anyway, and are known to break every once and a while. It very likely started a crank on one of the sides of that throw that completely broke off..
That throw further back in the engine seems to be were Pontiac cranks break when you run aftermarket balancers. Guessing this engine does not have the stock dampener. Stock balancers seem to break the crank further forward when they have trouble. The better balancer apparently moves the more severe harmonics further back on the crank.
I know people are tempted to reuse the harmonic balance when it looks ok after something like this. I learned the hard way, after something like this the dampener goes in the iron pile no matter how it looks.
Old 07-31-2023, 08:39 AM
Agreed, "Sluggish Oil psi" clue put the Block split 1st, then Crank.
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 07-31-2023, 09:23 AM
Tom Vaught's Avatar
Boost Engineer
Most of the failures on the 455 engine mains I have seen were at the #2 Main bulkhead,
This was at the #3 Main bulkhead I believe. Suspect a crank failure caused the block/ engine damage.
Tom V.
Old 07-31-2023, 11:21 AM
The two runs prior to the run when the engine broke the times were down .3 to .4 where it should have been running and the oil pressure seemed lazy to come up and was lower than normal at hot idle. This is the reason I think the crack down the #3 main was already there for a while and just getting worse but I am no authority just what I think. What is interesting is the bearing on the rods looked like new and the mains all looked pretty nice too. This was a low RPM motor I shifted at 5600 and went through the traps at around 5800. This engine started out as a low 12 second street car in 1986 and evolved into a low 10 second race car. Freshened up a few times over the years this was the third crank third set of heads and third cam but the same pistons and rods from 1986. I don't feel too bad this engine served me well thousands of street miles and hundreds of 1/4 mile and 1/8th mile runs over the years.
Tim Corcoran
Old 07-31-2023, 11:26 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
WOW! Sorry to see all of this Tim!
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
