Old 01-15-2024, 09:47 PM
Tom Vaught's Avatar
Boost Engineer
Default Ken Crocie engine build in Motortrend Magazine
This is a reprint of the work Ken C did years ago using a q-jet carb in Hot Rod Magazine
https://www.motortrend.com/how-to/cc...iac-400-build/
Tom V.
Mods put in Boost section if more appropriate.
Tom V.
The Following 7 Users Say Thank You to Tom Vaught For This Useful Post:
Old 01-15-2024, 11:40 PM
Jay S's Avatar
Jay S Jay S is offline
Ken’s persistence to make the qjet work with the turbo was amazing.
The Following User Says Thank You to Jay S For This Useful Post:
Old 01-16-2024, 07:09 AM
steve25 steve25 is online now
I just read that and my hat is off once again to Ken to get to the bottom of things.
That Q-jet fuel passage mod should be done on any NA motor that’s making over 400 Hp before any full throttle secondary metering rod changes are made it would seem.
Old 01-16-2024, 01:13 PM
Formulas Formulas is offline
I dont have Roe's book so just going by the motor trend article description... they are talking about the Qjet POE enrichment circuit?
correct?
Old 01-16-2024, 01:17 PM
grivera's Avatar
grivera grivera is offline
That’s a great article. I wonder why the Performer intake and not a factory cast iron.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 01-16-2024, 01:31 PM
grivera's Avatar
Will Rivera
Old 01-16-2024, 01:41 PM
Even though a factory iron intake flows more NA air then a Performer does the performer has better fuel distribution.
Kens motor was a blow thru turbo set up and that matters more .
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 01-16-2024, 04:09 PM
Pontiac Performance Author
Thanks everyone for the interest and kind thoughts.
Performer intake. I don't recall why ! The possibilities are:
1: The Engine came to us that way.
2: Mecham installed the Performer as part of the TurboForce package.
3: I just thought it was a good idea at the time.
Not all components are scientifically tested! (surprise)
BTW, we made brackets that attached the bonnet to the shaker, which allowed the shaker to look stock and shake with the engine on the TurboForce kit.
Carb. The the passage from the secondary well has a slight bend in it, and at the bend the secondary air bleed tube is positioned at the tightest part, potentially restricting flow. The amount of restriction varies carb to carb. Some limit flow , others don't. Our SS/KA Super Duty and friends SS Super Duties experienced this restriction problem. The symptom was the inability to get the secondary metering rich enough. To solve the lean problem ,we had to add more fuel than normal to the primary side- as in removing the primary rods and installing jets in the 80-84 range,
Now, I raise the secondary air bleed tube 1/4" to get it out out of kink and get full flow potential in that area. If that doesn't work, surgery is required. The procedure starts on page 134 of Doug Roe's Rochester book with copyright date of 1986. I understand some other editions have deleted this section.
The Following 2 Users Say Thank You to KEN CROCIE For This Useful Post:
Old 01-16-2024, 04:11 PM
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 01-16-2024, 04:29 PM
Sorry for the double.
BTW- after the carb got fixed, I ran the dyno in manual mode. I saw 830 #s at 2800 rpm. I wasn't about to sacrifice a numbers matching block for the sake of more power, so I pulled the throttle back almost immediately. Official dyno runs were performed by westech's Steve Brule'
Old 01-16-2024, 04:31 PM
Old 01-16-2024, 04:32 PM
Another double! dont know why
Old 01-16-2024, 04:38 PM
Ken, your not the only one with the double post thing taking place, it happens to me every darn time.
It’s a Fluke with the site that they seem to not care about since I have brought it to there attention twice and I know others have done the same at least once.
Once again thanks for your contributions here!
Old 01-17-2024, 05:39 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
The double post thing started a few months ago and it always tries to do it to me.
Was the power number tamed on purpose because of the factory block?
I have been considering a blow through centrifugal setup on my engine to turn the wick up a little, while still keeping street manners. I have the bottom end for it, but I sorta feel like Im nearing the top end of factory 400 block safe at NA. So Im concerned that adding a blower I might crack the block.
Old 01-17-2024, 07:14 PM
turbo69bird's Avatar
If I post I have to wait a minute (and I mean a minute for the first post to go through then it doesn’t double but if I hit it again to make it work it doubles .
I used a performer on my first blow through engine everyone said it wouldn’t work (Some big time turbo guys who worked on pro 5.0 stuff ) I’ve never been able to get my single plane to run as good as my dual plane . Even w efi. So for whatever reason it was used it was a good way to go.
I used mine because I built the set up the first time. headers and all in 48 hours to show up at a friends no time - street race at LVD car went 10.00 off the trailer . Which back then was pretty fast. That was no Intercooler and a washer fluid pump and a heating system nozzle for the water meth injection I even made the carb hat in my garage from sheet metal. Still have the intake carb and. Sheet metal carb hat in my basement. Had so much fun w that set up.
960 HP @ 11 psi, 9.70 at 146.
Old 01-17-2024, 11:44 PM
HP limit. 537HP wasn't chosen . I believe this combo reached it's natural limit due restrictions in some parts of the system such as exhaust manifolds, exhaust turbine housing, or the compressor itself. You will notice the boost was dropping off halfway through the test.. I could have increased the boost via wastegate adjustment But that would have increased low end torque with very little change in peak HP. Considering the customer had a limited production restored car and was probably running G60x15 TA Radials, he would have the power to "smokim" at any time.
Please note that all of the above is pure conjecture on my part.
