what crossmember to use when putting a TH400 Trans in a 81 Trans am?
a friend is putting a th400 and 400 in a 81 trans am, what crossmember does he need to use or can original th350 crossmember be modified?
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
I had a similar experience 40 + years ago with a 72 Formula. Yeeesh, that was a long time ago
I had pulled a 350 engine with auto trans, and replace it with a 400 engine and 400 trans. The shop that helped me was able to use the original crossmember. He told me he turned it around and just had to mount it a little further back to match up to the longer 400 trans mounts. My 400 trans came with the matching yoke and driveshaft that fit the Formula too. Sorry I can't give you any more details, as I didn't do the install myself. But that was a concern of mine too at the time. Your buddies 81 will really come to life with that combo...I know I had a blast in my ride. Last edited by stuta; 01-26-2021 at 06:59 PM. |
Yes, I knew about using the original crossmember and modifying it as you describe.
Wanted to give him options to do it right. thanks
back in 1980 i bought a new indy 500 ta and almost immediately pulled the engine and trans and put in a 400 with turbo 400. as for the crossmember, i cut the mount off and mounted it on the other side and it worked perfectly.
Thanks. I will let him know.
Sent from my Moto Z3 Play using Tapatalk
I tried the mount tab on the other side for my 500" IA/Camaro TH400. The deep pan hits but it cam be sectioned.. I ended up using a G Force/Summit crossmember,
i had a 455/th400 from a 74 firebird in a 78 t/a... i just used the original 74 th400 cross member & had to drill new mount holes in the frame an inch or 2 back. much easier than re-weldng the mount tab.
The Following User Says Thank You to 78w72 For This Useful Post: | ||
Flipping the mount around or moving the mounting tab over is a useful trick. You can easily make a larger slotted tab if needed for adjusting location easier. A spare mount may be useful for comparing mods and measurements to.
