73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 01-25-2021, 04:15 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Trying to turn engine by hand
I'm trying to do a distributor on a 350 olds I've got all the plugs out of the block except the one under the AC compressor how hard will it be to turn the engine by breaker bar to get it to tdc cause I know I have to do that
Sent from my SM-S111DL using Tapatalk
Old 01-25-2021, 04:47 PM
Sirrotica's Avatar
With 7 plugs removed, pretty damn easy, you should be able to use a standard 1/2" ratchet with no compression on any cylinder but one. A breaker bar would be overkill.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-28-2021, 09:36 AM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
You can turn an engine with all 8 plugs in. It's slow but it turns, not spins.
Old 02-03-2021, 12:52 PM
Whelp got it out distributor was fine this engine is toast!
