THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Work Bench
My step daughter made this vinyl decal for the top of my work bench. It’s butchers block and the decal is vinyl. Do I used polyurethane or what to seal and protect it? Sorry if this is the wrong forum but this one gets the most exposure and I couldn’t really think of a more appropriate one.
Moderator move to lobby. Didn’t think about it
i would poly or epoxy over it, it will get scratched but the sticker it self can be preserved. also could put a piece of plexiglass over it. and just replace the plexi when scratched.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
You could put poly or epoxy over it. Epoxy is way tougher but poly is easy to apply. As said either one will get scratched up over time depending on your use. Just put the sticker in a less used location. Looks cool!
a couple of coats of polyurethane or epoxy should protect that for years! I agree epoxy is stronger .
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
i
I just sprayed this last week with Satin Poly. It was only stain and was not sanded. had to lightly sand between coats |
Looks nice. but I don't care what you cover it with other than a sheet of plywood wouldn't last a couple months on my bench.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Have you already applied the decal to your work bench? If not, consider making a plaque with it to hang on the wall above the bench.
Remember no one is perfect. Everyone's butt has a crack in it! |
I think plexiglass is the only thing that will protect it if you want to be able to see it and you actually use it for a workbench. It's very nice by the way!
Greg Reid Palmetto, Georgia |
Lexan or Rhino type plexi, it’ll protect the whole top.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
Put it by the edge of top, or to the back, where it doesn't get heavy action. And yes, coat it.
72 Bird |
If you’re set on having it on your workbench, you might consider burying it in that thick “bar top” epoxy
Better than worrying about how to protect it, put it on a cupboard door over the work bench. It'll be far safer up there in the long run. And to protect it more on the door just use use a clear polyurethane over it.
Plexi, After years, you can replace it. Epoxy looks bad. Unless you put a Elvis head in there.
Well she already put it on my bench so moving it is out. It was a surprise. I am gonna polyurethane the hell out of it and just be careful. It’s just the bench in my garage not the one in my shop where heavy lifting is done. I will just have to try to be careful.
nice sticker .
67 gto 400/400/3.90(sold) 69 lemans vert 400/400/2.78 89 trans am 350/700r/3.27 67 lemans custom |
Thread Tools | |
Display Modes | |
