Old 10-03-2023, 01:18 PM
SD455DJ SD455DJ is online now
Default '69 Rust Free 4-Dr Sedan Driver Door Needed
I'm on the hunt for a clean, straight & rust-free driver door from a 4-door sedan or wagon (Tempest, Custom S, or LeMans).
Dennis
Old 10-07-2023, 08:21 AM
Default '68 Door would work too?
I imagine a '68 door are the same as the '69's?
Dennis
Old 10-27-2023, 10:21 AM
newmexguy newmexguy is offline
You might try Joe Vega, aka "azchevs". He has some four door doors in his yard. Sierra Vista, AZ.
The Following User Says Thank You to newmexguy For This Useful Post:
Old 10-27-2023, 04:12 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Dennis
I never even thought about the 4 doors possibly being the same. Does the 69 4 door still have the vent windows? I would assume that would be the only difference.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 10-28-2023, 05:43 PM
Yep, coupes and sedans (doors with frame posts around the windows) still had the vent windows through '72, wagons did too.
Dennis
ID:	622401   Click image for larger version
Old 10-28-2023, 05:57 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default 1968-1972 Pontiac intermediate 4 door hardtops
Along with the 4 door hardtops, through 1972 (so there is no retrofit factory part availability)
Dennis
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 10-28-2023, 07:16 PM
Yes, I forgot to mention them. I don't own any 4-dr hardtop A-bodies, just a '71 Bonneville 4-dr hardtop and they don't have the vent window like the A-bodies do.
Dennis
Old 11-01-2023, 12:25 PM
Hollander number is 2085. '68 and '69. Interchange section shows Pontiac only, with an "early" and "late" stamping, with different part numbers. MIght? be something to do with the movement of the lock rod farther away from the rear edge of the door, from '68 to '69. Although thought that was a H.T. thing, to cut down on "coat hangering" break ins.
