Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 12-10-2021, 04:56 PM
dataway's Avatar
dataway dataway is offline
Default 68 GTO Glove Box Screws
Just wanted to point out that the glove box screw set, PN A353AK for a 1968 GTO are the incorrect size. Considerably too small. Not sure whether you pack them yourselves or get them prepackaged from AMK etc.
See photos below. AMES part on the Left, Originals on the right. As you can see, when they are in place the head is almost small enough to fit through the mounting hole, and the threads will thread into your replacement glove box, they are too small and will strip out the metal inserts in the box.
Just a heads up that you might want to pull that product unless this was a one off situation. Happy with my glove box though, very sturdy.
ID:	579378   Click image for larger version
ID:	579379   Click image for larger version
ID:	579380   Click image for larger version
ID:	579381   Click image for larger version
Old 12-14-2021, 08:37 AM
Half-Inch Stud's Avatar
I bought a box of 100 screws on my own, from a hardware store: perfect match in size and finish. Welll i will repost if the part number is avail ( i might have tossed the cardboard box).
Old 12-14-2021, 09:16 AM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Thank you for bringing this to our attention! I'll check our current stock along with some originals that I have available. We'll post the results.
[/SIGPIC]
The Following User Says Thank You to AMES-TECH For This Useful Post:
Smilies are Off
