Old 06-21-2023, 12:00 AM
KGTO's Avatar
KGTO KGTO is offline
Default Sandalwood question
For those with sandalwood interiors, when in original CLEAN condition, does it have a "mottled" look to the vinyl/soft surfaces?
I'm working on a 70 with sandalwood that hasn't been cleaned in 30+ years. I have one of the panels exceptionally clean, yet it appears to have slightly darker spots throughout the surface that I call "mottled". It could be deeply embedded dirt, but I can't quite tell.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 06-21-2023, 12:16 AM
hawkins69 hawkins69 is offline
Yes originally will have slightly darker, spots in vinyl. Very subtle. Whatever you do, don’t paint dash, steering column and kick panels the lighter color as door panels. These should be a little darker color
Old 06-21-2023, 02:14 AM
KGTO's Avatar
Ok, that's what I was hoping to hear. I didn't think I could get it any cleaner
Yes its evident the other parts (column, dash, etc) are darker. The dash has one crack in it, so far leaving it. Thought of trying the dash cover, but I think a company is out there that will recover the original dash. Do you happen yo know if the darker parts are saddle?
1964 421 GP-Sold
Old 06-21-2023, 07:12 AM
scott70's Avatar
scott70 scott70 is offline
I believe theres actually a dark sandalwood which probably would go with the original sandalwood. My 70 gto is saddle with different interior parts and carpet dark saddle. And my door panels are also the mottled look.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 06-21-2023, 11:22 AM
KGTO's Avatar
Thank you that's helpful too.
I've been trying to search the correct color for the package tray. I don't know if it's sandalwood or the darker shade.
1964 421 GP-Sold
Old 06-21-2023, 01:26 PM
scott70's Avatar
My gto has dark saddle carpet,dash vinyl,kick panels and rear package tray,,everything else is saddle. The door panels are saddle but the carpet on the bottom of the door panel is dark saddle.
Old 06-21-2023, 01:53 PM
madeuce50's Avatar
madeuce50 madeuce50 is offline
1970 Parts Book paint codes for Sandalwood:
interior semi gloss
Medium Sandalwood Du Pont 9716-L Ditzler 23323
Dark Sandalwood Du Pont 9727-L Ditzler 23324
interior 0% gloss
Dark Sandalwood Du pont 9704-L Ditzler 23311
no medium Sandalwood listed
Old 06-21-2023, 02:42 PM
KGTO's Avatar
Would this imply that the package tray was originally a shade darker? I can't find any info anywhere and I ordered samples from Ames.
The original one was removed and replaced with tan audio carpet.
1964 421 GP-Sold
Old 06-21-2023, 10:33 PM
scott70's Avatar
My 70 is code 255 saddle but the original package tray was dark saddle. I had legendary make me a new one the same color.. Im assuming your rear tray would be dark sandalwood.
Old 09-19-2024, 12:20 PM
BobsGTO's Avatar
BobsGTO BobsGTO is offline
Default Sandalwood interior colors
Hello all, I'm a bit late to this thread, but wanted to ask you all what color you think is my dashboard painted with? I've had this GTO for 19 years and the interior is original, as far as I can tell. I did replace the carpet with a Sandalwood color through Ames.
I'm assuming GM installed a darker color dashboard to make is less "glaring" in the sunlight while driving - I've seen Parchment interiors on other GTOs with a Black dashboard, probably for that same reason. Any insight as to what my dashboard color is will be appreciated. Note: ignore the A-pillar color in one of the photos. I painted it Sandalwood, thinking it was incorrect and, depending on what the dash color is, I will return it to the proper color.
I've also included a close up of the original seat color, where you can see that mottling that one of you asked about.
ID:	640239   Click image for larger version
ID:	640240   Click image for larger version
Thanks,
Bob M.
1970 GTO Convertible
Originally: Sierra Yellow/Sandalwood Int/ Sandalwood Top w/ 400 4BBL Auto Trans
Currently: Red/Sandalwood Int/White Top w/ 400 4BBL Manual Trans
Built in Baltimore Plant - 1st week of Nov. 1969
Thread Tools
Display Modes
