Old 04-18-2020, 05:47 PM
OG68 OG68 is offline
Default More Steering Column Paint Questions
68 GTO Floor Shift Column
Column had lots of overspray and I'm trying to restore back to Regimental Red.
As I stripped the overspray off I found the original red over a black base coat.
Exposed section of column is Regimental Red, but was it painted red all the way to the firewall or just the base coat of flat black under the dash
Was the pedal and column support bracket natural metal or was it painted with overspray from the dash paint?
2007 Cadillac SRX
Old 05-21-2020, 01:26 AM
KGTO's Avatar
KGTO KGTO is offline
I just had my column restored, but it's black so I don't think that helps you. I would almost think your column would be red to the firewall.
The pedal mount on mine looked like it had a light dusting of black, I restored them and its all 60* gloss black now.
The mount for the column also seemed to be black, when they restored the column they restored this bracket too and its 60* gloss black which I believe is correct.
The parking brake pedal is black part way up and the rest is natural metal. Since mine had some light surface rust I had it soda blasted and did the same paint break, I used a satin clear over the bare metal and it looks very much like it would have been originally.
Hope some of that helps
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 05-22-2020, 09:53 PM
69gtocv 69gtocv is offline
Did you solve this? If not, I can go grab some pictures of my 68 red guts LeMans. It's a column shift, but I'm sure the painting process was probably the same
Old 05-23-2020, 01:00 AM
Photos would be great thank you.
2007 Cadillac SRX
Old 05-23-2020, 03:07 PM
Here you go Ed, let me know if you need additional ones. This is a 31k LeMans that has never had anything done under the dash. Pretty obvious whoever shot the paint underneath did it from the drivers side as there is hardly any red on the passenger side of the column.
Name:	68 underdash2.jpg
ID:	540804   Click image for larger version
Name:	68 underdash1.jpg
ID:	540805   Click image for larger version
Name:	68 underdash3.jpg
ID:	540806   Click image for larger version
Name:	68 underdash4.jpg
ID:	540807   Click image for larger version
Name:	68 underdash5.jpg
Old 05-23-2020, 05:05 PM
Thank you. Thats what mine looked like.
I thought it was over sprayed when the interior was repainted
2007 Cadillac SRX
