Old 04-29-2020, 07:37 PM
WillV's Avatar
WillV WillV is offline
Default Water pump leaking or timing cover?
Hey guys, my 69 GTO 400 , 11 bolt water pump is beginning to make noise so I think I'm needing a new water pump. Also, I noticed coolant at the valley pan where it meets the timing chain cover. Appears that I might need to replace gaskets all around and a new water pump. My question is do I need any special tools for removing/installing the timing chain cover. I've done water pumps but never the timing cover. Thanks a bunch all and stay safe! - Will
Will
Old 04-29-2020, 10:09 PM
Scott65's Avatar
Scott65 Scott65 is offline
It is fairly likely that coolant bypass is what's leaking. However, if your water crossover isn't separated from the intake, you'll need to pull either the intake or the timing cover to replace the rubber o ring that seals that passage.
Old 04-30-2020, 12:42 AM
WillV's Avatar
right, I'm thinking it's the timing cover. Any specials tools needed to do this.
Will
Old 04-30-2020, 06:25 AM
Scott65's Avatar
Getting the harmonic balancer off is potentially the only serious challenge.
Old 04-30-2020, 07:48 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Agreed. If I had to choose, I would take the intake off. Just dont find your self in a "Might as well" scenario.
A few things I would do if you have not done it is;
Make sure you have a cast impeller
Clearance the impeller.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 04-30-2020, 10:14 AM
78w72 78w72 is offline
if the leak is at the timing cover to intake, you dont need to remove the timing cover, taking off the intake will let you replace the rubber O-ring that seals to the timing cover. a leak at that spot is common, might just need to tighten up the bolt.
but if the WP is making noise & you are replacing it anyways, then just pull the intake when you do the pump. research how to clearance the impeller to the plate, use some good ultra black or grey permatex gasket sealer on both gaskets for the WP, just a thin layer spread out with your finger, & i use a thin coat on the O-ring too just to seal any pitting that may be there. also a big thing is to just start the intake bolts & tighten the timing cover to intake bolt to pull the intake forward to seal the O-ring, then tighten the intake bolts. retorque the WP & timing cover bolts after a few heat cycles & it should be leak free.
& there are no special tool to pull the timing cover... the balancer is slip fit so should come off & reinstall pretty easy.
Old 04-30-2020, 10:39 AM
1969GiPper 1969GiPper is offline
Just curious has the timing chain ever been replaced....how many miles on it?
Old 04-30-2020, 11:41 AM
WillV's Avatar
as long as I have owned this car - 1996 - I have not replace the timing chain and I believe it has 150K original miles
Will
Old 04-30-2020, 11:42 AM
WillV's Avatar
Thank you .. I think I will try this first
Will
The Following User Says Thank You to WillV For This Useful Post:
Old 04-30-2020, 05:50 PM
bill ryder's Avatar
bill ryder bill ryder is offline
If you do try tightening the long bolt, be CAREFUL. With the intake torqued down, nothing wants to readily move and the bolt is the weakest link!!! just saying
