Old 05-04-2020, 01:23 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Default O-ring receiver groove versus regular MLS head gaskets
I recently did a leak down on my motor. I was pleasantly surprised with my findings. My current motor is o-ring/receiver groove and I have approximately 20 chassis dyno hits and 12 passes (5 of which are 1/4-mile) at the track. The motor saw between 24lbs-27lbs of boost on any given run depending on atmospheric conditions and whether or not it was a 1/4-mile or 1/8-mile pass. Here are my results:
1- 3%
3- 13%
5- 14%
7- 3%
2- 3%
4- 17%
6- 15%
8- 10%
With my previous motors, I utilized MLS head gaskets and was changing them 20-30 passes, depending on the amount of boost I was making. On average, the motor was leaking down in the range from 30%-40%+ after 20+ passes. I could re-torque the heads and might get another 5 or so passes before I started loosing more ET and MPH.
Just thought I would share my results and if you are on the fence as to whether or not you are going to go o-ring/receiver groove or MLS...I would go the o-ring deal. Just my
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
The Following User Says Thank You to bad69bird For This Useful Post:
Old 05-04-2020, 01:27 PM
GTOGEORGE's Avatar
1/2” or 9/16” studs?
GTO George
Old 05-04-2020, 01:30 PM
RAIV55 RAIV55 is offline
I'm curious, is this a methanol engine? How much leakage are you willing to accept before refreshening?
Monty Frerichs
B&M Machine
Box Elder SD
Old 05-04-2020, 01:43 PM
bad69bird's Avatar
Sorry forgot to add...I'm on Q16 and 1/2" head studs. Also, there are no "inserts" in between the center cylinders.
Typically, anything over 30% I'm putting new gaskets on.
Old 05-04-2020, 02:05 PM
The copper gasket, o-ring and receiver groove has worked well on a multitude of high pressure applications. For what its worth, Usually pull 'em down when leakage goes over 15%. Zero gap top rings go along way keeping leakage in check over the long term.
Have you tried Titan head gaskets?
Monty Frerichs
B&M Machine
Box Elder SD
Old 05-04-2020, 02:08 PM
mgarblik mgarblik is online now
If you don't mind answering a few more questions to complete the picture? Do you run coolant in the engine? If yes, are you running coolant through the block to the heads or dry deck? Also, is your receiver groove in the block or the heads? Finally, are you using .041" wire or .070" or some other diameter? Thanks for the info.
Old 05-05-2020, 05:09 AM
bad69bird's Avatar
I have not tried them. I use SCE gaskets.
No problem.
I do run water through the motor and the head, but I am dry decked. I come out of the back of the block and cross over to opposing side of the head.
I believe the wire is .041".
Old 05-05-2020, 10:08 AM
I have always had good luck with copper gaskets and O-ring wire. Only exception is running anti-freeze in a street/strip situation. I think that's where the MLS gaskets really shine. The ridges and bridges around the water and oil holes on OHC designs really seal water and oil very well. For sealing compression, copper and O-rings is hard to beat.
Old 05-05-2020, 05:48 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
ICS Titan is made by SCE. I've used them, they worked well. SCE was in the middle of a relocating when I was looking to order a set. I couldn't wait, so I'm trying Flatout this time.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
