Old 04-30-2020, 10:30 AM
dcmoore2 dcmoore2 is offline
Default looking for largest tire for 65 Catalina 2+2 with Hurst 14x6 wheels
hello, looking to see what the largest tire size would be to fit under a 65 Catalina 2+2., without skirts. I assume the outer portion of the rear tire, where it will hit the inner fender, will be the limiting factor since the backspacing on those wheels is under 4". Maybe they don't even make a 14" tire large enough to worry about rubbing? I know you cant go too wide due to the 6" width of the rim. Thanks for any input,
Old 04-30-2020, 10:36 AM
63gpman's Avatar
63gpman 63gpman is offline
your limiting factor is likely going to be the 6" width on the rims. Most would say that a 205 or 215 is max you should go on a 6" rim.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 04-30-2020, 11:24 AM
Stuart's Avatar
Stuart Stuart is offline
Take a look at the sticky note at the top of this section - it's about the biggest tire to fit on a 1966 car, but 1965 will be very similar. http://forums.maxperformanceinc.com/...d.php?t=397313 If you'e sticking with 14" tires, the selection these days is so limited that you may not be able to find a tire big enough, let alone too big.
Old 04-30-2020, 06:44 PM
stevep's Avatar
stevep stevep is offline
I have 245/60R14 on my car. It was the biggest that I could get.
Name:	65 2-2 in Mendon.jpg
Old 04-30-2020, 11:26 PM
67GP428's Avatar
67GP428 67GP428 is offline
On my Hurst wheels. I'm running Coker Firestone Wide Oval Radial Redline FR70-14. I tried to find a taller tire. 26.4 tall.
1965 Pontiac 2+2 421 HO auto
1967 Pontiac Grand Prix 428 4 speed- sold
1968 Firebird 400 auto - sold
1967 Bonneville Brougham 2 dr. hardtop. 1969 AMC Rebel SST wagon-sold
Old 05-05-2020, 10:57 AM
geoh geoh is offline
Send a message via AIM to geoh Send a message via MSN to geoh Send a message via Yahoo to geoh
I have a newly restored set of Hurst wheels and am trying to figure out what tire to put on them. I understand that occasionally, using radial tires the trim ring would not go all the way down due to the way radials bulge. do you know of anyone having that problem and what kind of clearance do you have in the rear? I had thought that the 245/60 would present an issue. What kind tire would you recommend ?
Thanks.
Old 05-05-2020, 07:03 PM
stevep's Avatar
I think that I have Cooper Cobra's on there.
Old 05-05-2020, 07:44 PM
stevep's Avatar
This is all that I have right now
Old 05-05-2020, 09:17 PM
Probably the largest as in tallest size you’re likely to find in an affordable radial tire would be a 215/75-14, nominal height being 26.7”.
I picked up a set of lightly used Coker Classic wide whites for $400 in that size to mount on my Hurst wheels, they’re not going on a big Pontiac but they’re pretty much the biggest and tallest radial tire that fits nicely on a 14x6” wheel.
Old 05-06-2020, 07:38 AM
Tim john Tim john is offline
I ran a G70X14 on mine for 30 plus years in bias ply (Firestone Super Sports) then in 1983 I went to Good Year Eagle ST (Flying Foot) radials in 245's and had zero issue with my original trim rings. I liked how these sizes fit the wheel wells on my 67 GTO. Never any issue with rubbing, turning, bottoming out, no problems at all.
Tim john---
Name:	HURST wheels,  Center Caps 044.jpg
ID:	539315   Click image for larger version
Name:	Original HURST Wheel Images 004.jpg
ID:	539316   Click image for larger version
Name:	HURST Wheels 001.jpg
