Old 05-22-2020, 03:02 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default BDS intake on Wideport head?
Has anyone used a BDS blower intake on an Edelbrock Wideport head?
Old 05-22-2020, 08:07 PM
PM to you
Old 05-22-2020, 10:29 PM
GTOGEORGE's Avatar
I’m not sure a BDS intake will word on wide ports!
GTO George
Old 05-22-2020, 10:49 PM
69Goat1's Avatar
I either need a Blower top for my Gutsram or modify my BDS...I was going to run a pro charger originally but I am now thinking I want to run my Roots Blower on Alcohol on the 535 we are putting together...
Old 05-23-2020, 12:57 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Put a blower top on a Gutsram. I think you'll be happier in the long run. Way more room for things and much better air flow.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 05-23-2020, 01:03 PM
I'm also a strong believer in hat and port injection (both). The port injectors are easy on a Gutsram and I believe they're essential to a good safe tune that will prolong engine life. I also run EGTs in all eight cylinders to monitor cylinder tune.
Jim
7.75 @ 178 pass:
Old 05-24-2020, 10:14 AM
GTOGEORGE's Avatar
KRE massaged my BDS intake a lot to fit my HP heads.
GTO George
ID:	540865   Click image for larger version
Old 05-24-2020, 06:13 PM
taff2's Avatar
taff2 taff2 is offline
Looks a bit like my modded Offy 360 manifold, siamesed runners, are they open like this from standard or did KRE cut the divider walls out?
Old 05-24-2020, 06:39 PM
blueghoast's Avatar
GTO George
Looks just like my intake. Except the intake devider's.
GT
Old 05-28-2020, 12:49 PM
GTOGEORGE's Avatar
GT
Well there kind of a spacer....the BDS intake (or at least mine) wasn't wide enough with the HP heads so they made the spacers, been working OK but there is only so much meat on the BDS intake to grind away. The intake is good enough for 7.90's at 171 in a 3,200 lbs car in 85 degree temps!
GTO George
Old 05-28-2020, 12:51 PM
GTOGEORGE's Avatar
BDS blower intake has NO dividers for the ports, wish it did.
GTO George
