Old 10-07-2014, 05:32 AM
strato gto's Avatar
strato gto strato gto is offline
Default 69 Trans Am Carb Screen
What holds down the carburetor screen on a 69 TA.Mine seems to want to just sit there.Is there some kind of attachment?Maybe a spot of clear silicone?
Old 10-07-2014, 09:57 AM
tom s tom s is online now
Nothing.have never had mine come loose.The air going in the carb will suck it down anyway.Tom
Old 10-07-2014, 04:28 PM
strato gto's Avatar
One or the other may be repro.Maybe I take the pan off and try to fit it off the car.
Old 10-07-2014, 07:48 PM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
On an original lower pan there are a few indentations or dimples around the perimeter of the rolled lip that sits on the top plate of the carb. These indentations "somewhat" lock the crimped ring on the screen into the base. Either way, the screen is likely NOT going anywhere.
Old 05-18-2020, 08:24 PM
tolerico tolerico is offline
To add to this old thread... these reproduction parts simply do not fit together -- so that is why the screen does not properly seat in the ram air pan.
Likely 2 different manufacturers that failed to communicate with each other when making them.
A shame since the screen is like $80 and a well made part. But the repop pan does not accept it correctly.
Old 05-23-2020, 06:58 PM
I can tell you that those screens were available long before the lower pans were. Even though there were likely a couple of suppliers of the screens over the years they were probably designed to fit an original pan not a reproduction.
