Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 08-10-2015, 01:44 PM
Old Goat Racer's Avatar
Default Lock ferrules
F203 I just tried to install 1 on my 65 GTO. Per instructions I soaked it in boiling water.
Immediately tried to install it & trashed it. Couldn't even put the lock back in.
Boiling water, is that how they did it on the assembly line ?
Everybody knows somthin.
Nobody knows everything !
Old 08-10-2015, 04:46 PM
GT182's Avatar
GT182 GT182 is offline
I don't think so. Just like they didn't have to bend water pump divider plates.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-10-2015, 06:12 PM
Jeff Hamlin's Avatar
No the original were a heavy thick pliable plastic.
The ones offered now are pure sh!t, even after you get them in they are bound to break in short order. I replace them almost every season.
Funny thing is I just had the '66 on the show field in Norwalk and my DS ferrule split and fell off from the "heat" junk I say! :)
Old 08-11-2015, 02:22 PM
Looks like they have tried several times
Select Catalog
Model Year
Product
Sort by
Part# Description Price Action
5080
1964-1967 DOOR LOCK PULL FERRULE (RE)
Details Unavailable
51021
Details Unavailable
6446
Details Unavailable
6447
Details Unavailable
6472
Details Unavailable
F203
1964-67 DOOR LOCK PULL FERRULE (RE)
2.00
Details
Old 08-11-2015, 05:17 PM
hakansan's Avatar
hakansan hakansan is offline
Select Catalog
Model Year
Product
Sort by
5080
Details Unavailable
51021
Details Unavailable
6446
Details Unavailable
6447
Details Unavailable
6472
Details Unavailable
F203
2.00
Details
Where did You find this?
On Ames site?
`70 GTO, 370 hp, 3:90, TH400.
Old 08-11-2015, 05:34 PM
I'm looking into something along this line so as to be done with the plastic crap.
http://www.ebay.com/itm/70-80s-GM-Do.../160983269379#
Old 08-11-2015, 09:50 PM
On Ames site?
yep
Old 08-11-2015, 10:23 PM
NOT compatible with 65 GTO
Old 08-13-2015, 06:52 PM
...same for '66. I'm just over replacing them every season so looking into something similar to the late model "metal" type to be done with it.
Old 08-13-2015, 08:42 PM
Let us know how that works out
Old 08-16-2015, 07:42 AM
chrisp chrisp is offline
File the hole in the door to remove paint buildup then install
Old 10-19-2019, 08:34 PM
LATECH's Avatar
LATECH LATECH is offline
Tried to put an AMES ferrulle in today. Finishing the interior on the 64
Heated one with a heat gun. It wouldnt go in. Third time I heated it,it melted.
They are pure crap.
I saw some metal ones for a mopar that have the 4 metal tangs that are bent over when installed.
I am considering ordering themjust to see if they fit the hole.
Guess I could e mail the guy for a diameter measurment.
Old 10-19-2019, 09:28 PM
Cardo's Avatar
Cardo Cardo is offline
I just went through the same thing. Ames ones even chipped my paint. Buy the ones from the Parts Place. They're made out of a different materiel, they are actually somewhat soft. They fit well in the hole, but file the center out slightly first so the lock button fits better. Much much better and easier.
"I know just enough to keep me here, but not enough to get me out"
Old 10-20-2019, 01:35 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Nothing like OEM assembly line parts.
Chris.
ID:	522532   Click image for larger version
ID:	522533   Click image for larger version
ID:	522534   Click image for larger version
Old 10-21-2019, 08:24 AM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
They are pure crap.
A heat gun is not recommended for these ferrules. Boiling water will distribute heat much more evenly, without melting the plastic. We have sold thousands of these exact ferrules for years using and recommending this method, with great success.
[/SIGPIC]
Old 10-21-2019, 10:28 AM
AMES-TECH's Avatar
They are pure crap.
Please send over an email to kyler@amesperf.com, and I can get another set out to you to try with boiling water.
[/SIGPIC]
Smilies are Off
