Old 03-02-2020, 02:10 PM
KGTO's Avatar
KGTO KGTO is offline
Default Any room for EFI bungs on BDS intake?
I think Steve Barcak was able to squeeze port injectors into his BDS intake years ago, any way at all to do it with EFI? I will have a little more room since the blower is only 7" wide as opposed to the footprint of a normal roots blower of 12.25"
Whipple 245AX
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 03-04-2020, 01:22 PM
GTOGEORGE's Avatar
Lots of luck, I was trying to figure out how to squeeze in injectors for a mechanical fuel injection!
GTO George
Old 03-06-2020, 04:38 PM
ErikW's Avatar
ErikW ErikW is offline
Default Injector plate
This do you any good?
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 03-06-2020, 05:54 PM
GTOGEORGE's Avatar
I think he's looking for something that attaches to the intake for individual cylinder tuning......like me.
GTO George
Old 03-06-2020, 06:30 PM
KGTO's Avatar
Thanks Erik, Agreed it would need to go into the runners
1964 421 GP-Sold
Old 03-06-2020, 09:06 PM
GTOGEORGE's Avatar
I thought you wanted something into the intake port.
GTO George
Old 03-11-2020, 07:22 PM
KGTO's Avatar
The whipple will be here tomorrow, but reviewing the footprint of the 245 4.0l blower I bought and the footprint of a roots blower it appears I will have around 2.5" on each side of excess room. I have a few ideas that might work
1964 421 GP-Sold
Old 03-12-2020, 01:10 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I don't know about the BDS manifold, but on my hemi V8 I managed to squeeze port nozzles into the top corners of the fabricated blower manifold.
Old 03-12-2020, 07:26 AM
taff2's Avatar
taff2 taff2 is offline
You don't have to weld in bungs, there are efi injectors available that thread into a tapped hole -Atomiser does them- they also have a threaded top so that you can run individual lines to them instead of using fuel rails.
Old 03-12-2020, 04:58 PM
KGTO's Avatar
Really?? Have a link?
1964 421 GP-Sold
Old 03-12-2020, 07:46 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
This help?
https://www.dragzine.com/news/fuel-u...ting-injector/
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 03-13-2020, 07:03 AM
taff2's Avatar
Yes that's them, Turbo2 on YB is a dealer for them. Much safer than a fuel rail and easier to diy fit to any manifold. Shame their so pricey.
Old 03-14-2020, 03:01 AM
KGTO's Avatar
Just a wee bit
1964 421 GP-Sold
Old 03-14-2020, 05:01 AM
Brian Baker's Avatar
I've done it with mechanical injection. With a BDS and a 14-71. One injector in each intake runner, plus the 8 up in the hat. I never ran it of course, but that has little to do with whether or not you've got the room to fit the nozzle bodies. It just takes some massaging. I'll see if I can find some close up pics in the next few days.
Old 03-14-2020, 10:19 AM
KGTO's Avatar
Thanks Brian that would be helpful
1964 421 GP-Sold
Old 03-28-2020, 09:48 PM
AIR RAM AIR RAM is offline
I had looked into this to run with a turbo set up and planned to use a Holley High Ram top and a single bore throttle body. I also planned to run a 4" inner cooler made to mount below the Holley high ram lid. This would have made room to mount injector bosses since the Holley high ram lid is not as wide as the BDS blower. All I would have had to do is make a base plate and weld that to the BDS lower intake manifold and remove unneeded material and add the injector bosses.
With that said, one issue that needed to be address is that the BDS intake does not have dividers between each paired intake port... it just runs one large runner to the head. So aside from crap air flow into the cylinder, running a single injector per cylinder could potentially bleed over to the opposing cylinder making tuning difficult to nail down. I planned to install dividers to increase air flow velocity into the ports and shroud the injectors and keep them separated from the paired cylinder...
so with minor work... yes.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 03-29-2020, 11:18 AM
KGTO's Avatar
That's good info thank you. I'm rethinking the whole BDS intake. I'm thinking of building another one out of a gutsram like I did on the drag car. The Whipple is not very tall and looks like it will all still fit under the hood.
1964 421 GP-Sold
Old 03-29-2020, 04:24 PM
taff2's Avatar
A lot of blower manifolds have a siamesed intake runner - (no port wall dividers), it allows the head port to pull from a much bigger area and the airflow stream can be a straighter shot. I used a similar process on my previous turbo combo, I modified an Offy dual quad manifold and then cut out the port dividers, and then also cut out the port dividers in the cylinder heads - the airflow had a MUCH straighter shot at the valve. Cylinder to cylinder flow variations seemed to be minimal based on plug readings and driveability was pretty good considering the huge manifold plenum volume and dual 600 double pumpers. It is something I will be playing with again once I have the Holley sequential EFI system set up and baselined, as I believe there are power gains to be made here. I only tested this to just under a 1000 hp (at 17-18psi on factory 96 heads)
Old 04-24-2020, 05:57 PM
Is this not something you expect to benifit a WOT application only? It would be interesting to see a DYNO of with and without dividers just to see where exactly in the RPM is effected... I just have a hard time seeing any benefit to such a mod at the low to mid range.... sure on a drag car I get it, who cares about low to mid range when your WOT from start to end. If there are gains to be had at WOT.... then it sounds promising. I cant see it being a worth while venture for a street/strip car that needs low to mid range power to reasonably function however I am always willing to learn something new. Looking forward to what you learn after more comparison testing with removing the center dividers.
SPEED SAFE, NICK
Old 04-25-2020, 05:33 AM
taff2's Avatar
Yes, drag race use only, though driveability was fine.
Thread Tools
Display Modes
