Old 04-09-2020, 07:54 PM
punkin punkin is offline
Default Rocker Covers, Throttle Cable, Wiper Motor
Hello all,
I'm in the middle of replacing a motor. Now is the time to get some things cleaned up in the engine bay and freshen things up.
I'm considering a new set of rocker covers and I've got my eye on a set of fabricated aluminum. The only thing is, when I was looking at the drivers side firewall, things are a little tight there. I'm concerned with interference with the wiper motor and possibly the accelerator throttle cable.
Any one with aftermarket valve covers that are taller than factory but still fit in that tight space? Curious how tall a valve cover you're able to use.
Thanks!
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 04-10-2020, 09:51 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
The wiper motor unit is often an issue when it comes to larger valve covers. I've used New Port Engineering for replacement wiper motors.
Old 04-10-2020, 07:40 PM
I will definitely look into that. Thanks!
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 04-11-2020, 10:06 AM
Here's a photo of the New Port wiper on a 1st gen bird. Sorry for the poor quality. It's a photo of a photo and upside down !
Old 04-11-2020, 11:37 AM
grandam1979 grandam1979 is offline
I have 3/4 spacers under stock chrome covers and everything still fits ok.
Old 04-16-2020, 05:54 AM
What was the installation on that wiper motor like? Did it utilize existing wiring hardness connections or was there a lot of wire cutting and splicing to do?
Thank you for sending the photo.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 04-16-2020, 09:58 AM
The wiper motor came with a wiper switch. The wiper kit is set up for a two speed wiper. They do offer upgrades like wiper delay. But to answer your question. The wiring for the wipers is a stand alone set up. You have to supply a power source [fused] and a ground. I see no reason why you can't use the Firebirds wiper power source. Which would give you the factory wiper fuse in the fuse box. A nice feature with the switch. I was able to used the original wiper knob.
The Following User Says Thank You to Hammertime Mike For This Useful Post:
Old 04-16-2020, 09:11 PM
I thank you very much. This has been very helpful.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 04-17-2020, 11:13 AM
Speargun's Avatar
Speargun Speargun is offline
DIY Hidden Wiper Motor
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
The Following User Says Thank You to Speargun For This Useful Post:
Old 04-18-2020, 05:27 AM
Originally Posted by Speargun View Post
Awesome! I thank you.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
