Old 04-14-2020, 07:49 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 62 GP 389 plug wire routing drivers side Picture?
Anyone have a picture of 62 GP drivers side plug wire routing? I have a metal post loom thing that bolts somewhere on the intake (it was off when I bought the car) but I’m not exactly sure how it’s turned). I think I know the bolt hole it goes in. Thanks Jim
Old 04-16-2020, 05:37 PM
DiamondJim's Avatar
I’m talking about the factory vertical metal spark plug wire loom that bolts to the intake. I think I see the hole but how is it turned. Thanks
Old 04-17-2020, 10:25 AM
pfilean's Avatar
pfilean pfilean is offline
What do you mean by "turned"? I thought the ones I had seen were hex rod threaded on each end. Turning with a wrench should be easy.
Old 04-17-2020, 10:44 AM
Stuart's Avatar
Stuart Stuart is offline
This is a picture of the engine in my '61, I think the looms are the same as 1962 (sorry the picture isn't very large.)
Old 04-17-2020, 11:41 AM
61-63's Avatar
61-63 61-63 is offline
The is of Paul Glascos '62 Catalina and GP would be the same.
Name:	norwalk pictures 018 (450x800).jpg
Old 04-17-2020, 07:37 PM
DiamondJim's Avatar
This is the loom that I’m asking about. I think it’s purpose is to elevate the plug wires above the mechanical carb linkage. I’m not sure where it was mounted and how it was turned. Does the bottom L mount with the L toward the firewall or toward the passenger fender? Yhank
Old 04-17-2020, 07:54 PM
Stuart's Avatar
It mounts like what is shown in the picture 61-63 posted.
Old 04-17-2020, 08:08 PM
DiamondJim's Avatar
Thanks.! Thanks for the pic 61-63!
