Old 04-19-2020, 11:27 AM
TransAm400 TransAm400 is offline
Default Catalina Steering Box Options
Just got done replacing all the front and rear bushings, ball joints and tie rods on my 64 Catalina. It’s now apparent that the steering box needs some help also. Did some searching on the forum and it appears that the JGC, 2nd gen Fbody and other boxes will fit as an upgrade. Just wanted to double check and make sure that these boxes will in fact bolt up in the rear steer Catalina. I know about the need for metric adapters and new rag joint.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 04-19-2020, 12:28 PM
694.1 694.1 is offline
2nd gen, yes. JGC is for A bodies.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-19-2020, 07:08 PM
AZ64GP AZ64GP is offline
The one thing to consider though in one of our cars is there is a different limit to the turning stops in the F-body steering box. It is my understanding that if you install a F-body steering box in our cars, you will not be able to turn as sharply. You can go into the box and change these limits, but it's a headache. I have heard that the JGC, A-body cars, etc. have a steering limit similar to ours, so no problem there. I installed a '70 442/SS/GS/GTO variable-ratio steering box in my '64 GP.
Old 04-19-2020, 07:36 PM
stevep's Avatar
stevep stevep is offline
Use a mid 1970's box.
Old 04-19-2020, 09:41 PM
61-63's Avatar
61-63 61-63 is offline
Or just send your box to Lares Corp. in Cambridge Mn. and have it rebuilt.
Old 04-19-2020, 09:48 PM
I would talk to Turn One and see if a 600 series Delphi type box fits - I cannot stress enough the improvement it is over the Saginaws, GC or otherwise.
Old 04-19-2020, 11:08 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Do they make a manual Delphi box that will fit a 63 Lemans?
Old 04-19-2020, 11:12 PM
I do not know - you would need to ask Turn One...
Old 04-20-2020, 09:34 AM
I have a 670 built by Lee for my TA. Not looking to get into all that on the Catalina. Just looking to replace the old worn box and get a little upgrade at the same time. I think I'm going to try a Lares rebuild from Rock Auto.
1965 GTO 389/4speed
Old 04-20-2020, 11:45 AM
webfoot's Avatar
webfoot webfoot is offline
This is what I put in and yes it is a direct bolt-in. You'll have to add adapters to change it from metric to "pontiac" size IIRC.
Mine doesn't drive yet so no feedback on how well it works.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
