Old 04-19-2020, 08:29 PM
mback12000 mback12000 is offline
Default Need Dimension for 68 Ram Air air cleaner base
Seeking some help...if anyone can take a sec and measure their ram air air cleaner base.
I'm looking for the outer dimension of the 68 Ram Air air cleaner base. Or equivalently, the outer diameter of the foam base-to-hood seal (should be same dimension).
As background, I'm fabricating a custom air cleaner base due to a special intake/carb setup but I'm trying to make it look reasonably stock. Ideally I would use a repro seal and I need the correct O.D. of the shelf that it sits on.
If anyone can grab a measurement for me I would be grateful.
Mike B
1968 Firebird
Old 04-20-2020, 12:04 AM
brians's Avatar
brians brians is offline
The base is 19-1/2" diameter with a slight flat area in the back.
Foam is 1" thick, 1-1/2" height
“If you ain't first, you're last” - REESE BOBBY
Old 04-20-2020, 07:16 AM
Super helpful, thank you sir!
Mike B
1968 Firebird
