Old 04-29-2020, 10:34 AM
dcmoore2 dcmoore2 is offline
Default what lower quarter panel and wheel well opening are the same as 65 GP
I am about to start taking on a 65 GP which has a good bit of rot around the wheel wells and behind the rear wheel. I was hoping to find other quarters that could be used as donors to get the wheel arch at least. I assume the Catalina is the same wheel opening since I have seen skirts fit either. Finding 65 GP quarters or repair panels appears to be impossible.Thanks.
Old 04-29-2020, 02:48 PM
misterp266's Avatar
Default Try Franks
https://www.frankspontiacparts.com/u...iacpartsp2.htm
He has a quarter panel and a rear wheel well section for a ‘65.
" Darksiders Rule "
Old 04-29-2020, 08:20 PM
stevep's Avatar
stevep stevep is offline
Any 65/66 B body Pontiac has the same rear wheel opening
Old 05-13-2020, 10:18 PM
70ra455's Avatar
70ra455 70ra455 is offline
there are inexpensive lower qtrs for sale and u can get those sections from them
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 05-19-2020, 09:55 AM
Awesome - that is what I have been looking for. I have found inexpensive lower quarters for about everything but that specific 65 grand prix. Who makes or sells them?
Old 05-21-2020, 08:51 AM
a421cat a421cat is offline
Check out Cross Canada panels. They list lower quarters for a 65-66 Pontiac. These are not model specific. Will fit all except Bonneville. I have heard the wheel openings are not super accurate so may require metal work if you want to use your skirts.
I have a pair of outer wheelhouse sections I salvaged from a car years ago. Can send pictures if you are interested. Good luck.
Bill.
Old 05-21-2020, 08:54 AM
70ra455's Avatar
GP is the same as Catalina and even a Bonneville patch can be used on the lower section with some cutting to trim down the length but the wheel curves are exactly the same
Old 05-21-2020, 10:33 AM
marxjunk marxjunk is offline
can you post a link? or company name..cuz i cant find them and have been searching..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 05-21-2020, 10:29 PM
misterp266's Avatar
Cross Canada website shows L & R Rear quarter patch panels for ‘65- ‘66 full size.
https://ecat.crosscanadaparts.com/ba...ge=welcome.php
" Darksiders Rule "
Old 05-22-2020, 08:00 AM
Part numbers are: RRP3297 or 890-86BL for the driver side and RRP3298 or 890-86BR for the passenger side. Don't know why they quote two part numbers for each piece..
Old 05-22-2020, 01:17 PM
thanks - I thought I had looked there before. They do not show up when searching under the grand prix section, only the Catalina section. The price seems reasonable, but I bet the shipping will hurt!!! Maybe not terrible if I get both sides at once. I assume people here purchase from them regularly?
Old 05-22-2020, 03:10 PM
rustyrelic rustyrelic is offline
I bought what I think were similar quarter skins for a 68 and after they arrived it took about 2 seconds to decide they were two ill formed and thin to be of much use. Hopefully what you are looking at is much better.
I think it may cost you a bit more up front for some cut patches from a junk yard, but the long term result will be more than worth it.
I'd keep looking if it were me.
Old 05-22-2020, 06:11 PM
misterp266's Avatar
That’s why I mentioned Franks. Nothing is better than original. Second best would be to form your own patches from scratch. JMO.
" Darksiders Rule "
Old 05-23-2020, 10:22 AM
Big Bear's Avatar
Big Bear Big Bear is offline
https://youtu.be/OJCfLJbcXwY Here is a video of doing rust repair to a 65.
