Old 05-05-2020, 04:18 PM
Gary Smith Gary Smith is offline
Default Where Is The Temperature Sensor Located On 79 Trans Am 400
I have been looking all over the engine looking for the sensor and I cannot find it. I had to replace the radiator. Because the heater core was as old as the radiator and I do not want to tear out the dash I by-passed the heater core. I replaced the thermostat also. The temperature gauge worked before the changes. It does not work now. Thank you in advanced.
Old 05-05-2020, 04:32 PM
form74's Avatar
form74 form74 is offline
Should be in the Drivers head, check to see if the wire came off of it.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
The Following User Says Thank You to form74 For This Useful Post:
Old 05-06-2020, 07:54 PM
Thank you very much. I swear I looked all over the engine to no avail. You are right it is on the left head. Thank you again.
