Old 05-10-2020, 10:21 AM
weranc55's Avatar
weranc55 weranc55 is offline
Default 80 amp bracket and pulley
looking for a 80 amp set up
Old 05-10-2020, 08:09 PM
JLuger's Avatar
JLuger JLuger is offline
I have a 80 amp alt and power steering setup off a 73 455 if that's what your looking for?
Old 05-10-2020, 08:49 PM
weranc55's Avatar
Post a pic of what you have
Old 05-10-2020, 09:27 PM
JLuger's Avatar
PM me a cell# or email if you want and I will send.
Old 05-10-2020, 09:35 PM
weranc55's Avatar
8472263444
Old 05-10-2020, 10:22 PM
Scott Thelander's Avatar
Default and
I think there is 2 different set ups...
I just dont have a complete one
is there a stationary style like my first 2 pictures
and uses that tentioner pulley you have in your picture
and
the adjustable alternator for the 80 amp in my second picture ?
Scott
ID:	539880   Click image for larger version
ID:	539881   Click image for larger version
Old 05-10-2020, 11:28 PM
weranc55's Avatar
I need the tensioner pulley and brackets like I pictured.
Old 05-10-2020, 11:29 PM
weranc55's Avatar
and
Scott
So you think 71 was a one year only setup on the drivers side?
Old 05-11-2020, 08:58 AM
FrankieT/A's Avatar
Are you looking to up your alternator output and are you trying to keep your car original looking? If your not to worried about originality, the 105 amp alternator from a 1990 corvette is 100% bolt on(except for pigtail), charges at an idle(bright headlights at an idle) and looks similar to the original.
Old 05-11-2020, 11:29 AM
weranc55's Avatar
Thanks but I want the factory setup
Old 05-11-2020, 06:54 PM
rockys1970 rockys1970 is offline
PM sent.
Old 05-11-2020, 08:28 PM
The stationary 80 amp front mounting plate along with the idler pulley was used on '71-76 F-body's, as well as '71 Pontiac A-bodys built up into mid April of '71. In mid April '71, 80 amp equipped '71 A-body's began to be assembled with the front alt mtg plate w the adjustment slot.
Minute detal wise, the alum pivot block changed part numbers, & at least two different design stamped steel pulleys were used as idler pulleys. the latter being able to have its small bearing removed & replaced.
Old 05-12-2020, 11:23 AM
weranc55's Avatar
I found one. Thanks for the help
