Old 05-13-2020, 06:58 AM
Koppster's Avatar
Koppster Koppster is offline
Default Water Pump Wisdom
I'm installing my new Flowkooler and have a couple of questions:
1. I can't remember if I used Permatex sealant (Ultra Gray) on my last install, should I use it?
2. I purchased the new Stainless Steel divider plate and I am struggling to get it to bend for clearance. Thinking about cleaning up my old plate and using it.
Thanks,
Rick
Old 05-25-2020, 11:57 PM
64speed's Avatar
64speed 64speed is offline
I used blue permatex when I put my water pump on. No leaks. As for the clearancing of the plate I would think light taps with a dead blow should do it. Mine was already clearanced close enough when I did the water pump install
The Following User Says Thank You to 64speed For This Useful Post:
Old 05-26-2020, 10:00 AM
78w72 78w72 is offline
i always use something on water pump gaskets, the ultra grey & black is great stuff. just dont overdo it, use a very thin 1/8" bead or even thin it out with your fingers before assembly, use on both gaskets. & if the intake to cover area is pitted at all a thin layer on the rubber O-ring wont hurt either. anti seize on the bolts too & dont over tighten. after a few heat cycles snug the bolts up again.
the stainless plates are much harder metal & dont bend as easily or evenly as the stamped steel ones, if its in good shape just reuse the original if you cant get teh stainless one to clearance right.
