Old 05-22-2020, 07:34 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 1962 Exhaust manifold nipples?
On the passenger side exhaust manifold on my 62 GP right above the exhaust pipe flange connection there are 2 nipples sticking out. What did these used to be for?
Old 05-22-2020, 08:30 PM
DiamondJim's Avatar
I’m guessing what I’m seeing are the remains of an exhaust manifold heat riser valve?
Old 05-23-2020, 12:07 PM
mgarblik mgarblik is offline
That is very likely. If the flap and shaft are gone and you don't mind doing without, the shaft holes can be brazed up pretty easily
