Old 05-28-2020, 12:52 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Default NGK Plug
Good day everyone... Does anyone know if a NGK Spark Plug exists that is the same as the NGK R5673-8, but in a Resitor plug? They are for 6X heads, and need to be 5/8" wrench, .460" reach, tapered seat, perferably "Non-Projected" tip. The engine is a 461 with a single SXE480 billet turbo making maybe 800+hp with 10-15 lbs of boost. 100% street car on pump gas. I will be running the Holley XFlow 1375 EFI, and it recommends "Resistor" plugs to keep RFI problems in check. I think the heat range of the R5673-8 would work great for me, but I need it to be a "Resitor" plug. Anybody have a recommendation for a part number? Thank You
1978 Trans Am
Pump Gas 461 Stroker
Old 05-28-2020, 02:34 PM
ok, after more research, I'm actually starting to lean more towards a "projected tip" plug for this application, since it is street driven. I have came to that conclusion after reading a comment over on one of the turbo forums, where a NGK Tech had responded and explained that, even with boost, it is better to run the projected tip in a street application, since it keeps the tip of the plug burned cleaner, keeping it from fouling. The coldest "Resistor" plug I can come up with in the NGK, with a tapered seat, .460" reach, 5/8" wrench is the NGK UR6(7773 Stock Number)plugs. The NGK Tech says it is 2 steps colder than stock Heat range, so that should work for me. I have since read quite a few people using them with great results in Street boosted applications as well. Anyone see any problems with the UR6 plug in this application?
1978 Trans Am
Thread Tools
Display Modes
