#401
[QUOTE=mike leech;5585605]
... if you add 350hp of N20 to an engine that makes 900hp N/A will certainly make less power than an engine that makes 1100hp N/A with 350hp of N20 ... ... and i'm trying to be honest with you, not rude, just honest ... |
#404
... no sweat Paul, we all need some humor now and then ...
#405
... but something else i would really like to see, if for just once, one of these threads can actually turn into a hardcore, genuine Q&A session, where people are not trying to push one head in front of the other, with enough time the heads will show that ... ... i'm talking about guys at the high end of the RPM game are actually in the position to answer questions, or maybe even ask a couple, in a thread where there is no BS comments or hatred towards each other, a truely open format, where there is no stupid question, and it's answered as such, it goes a really long way to show respect to others, and that alone can really boost someone's interest or even ability to understand new information ... ... hell, some of the meanest MF's in the world in the UFC beat the snot out of each other, and at the end of the match, they get up and shake hands etc ... ... we can do better ... if you guys want to push this market forward, it starts with discussion like i just described, because i can promise all of you one thing, any engine does not care what color you paint it, what decal is on the hood, or what you THINK it should do, 100% of the time and ALWAYS, the engine is right, not us ... |
#406
... those type of comments read like a N20 car really doesn't rely on how much power the engine makes on it's own, which is well, not correct ... that's all i meant |
#408
And mine as well, lol. So why bring it up??
#409
... very simple, because what the engine makes N/A will effect what it runs on N20, that's why ... the way that reads is N/A power makes no difference what the car runs on N20, which is totally false ...
... got it ??? ... |
#410
I am after Very High Velocity Heads like my 1970 RAIV's. In the Future . Perhaps late Summer I could give a Fick Less about Peak Air Flow numbers.. Average under the Curve. E/I ratio. Must Be 100 % dependable. Run Time 9-seconds to 2 minutes Wide Open Throttle . Zero Failures. Street Racing at at night. Combinations of Drag Racing & Endurance Racing. Last edited by wheneaglesfly; 06-07-2016 at 08:07 AM. |
#411
8,000-9,000 RPM Peak.
6200-7000 Rpm will beat 97-99 % of all. |
#412
Engine size and RPM, and HP goals are needed. Calvin Hill Hill Performance 708-250-7420 |
#413
Thanks you for touching on that point. Velocity is dependent on the flow coefficient of the cross-sectional area and pressure differential on the runner. Small or big ports only tell a portion of the story . Many people think they're going left but are actually going to the right on this subject.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#414
The flow bench is just a test device. The head will see a much different velocity on the engine @ wot @ peak power and this is the one that counts.
Stan
#416
^^^Truth ^^^
#417
But the good porters can correlate this data to what works and doesn't work on the strip.
#418
They may not even have to be "good" if they are experienced and smart.
#419
... well, enough experience and smarts, usually equals GOOD ...
#420
