Closed Thread
Old 10-29-2020, 04:52 PM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
Default CV-1 2pc (CVI-1R)Manifold results ...
Well, Mr. Belehar has just completed some back to back testing for us with the CVI-1R 2pc manifold vs his low rise single 4 manifold, both manifolds have been port matched to his CV-290 heads but not ported, the low rise has my Anti-Reversion kit i like to use from Reher-Morrison that I modify slightly ... you can look at the pics for more details but the "R" manifold had immediately created traction problems, so much so Randy's had ended up pulling out 12 degrees of timing for (.9 seconds) into the run, he got one pass that it didn't spin afterwards and went 9.25 @ 145mph with a 1.29 60ft 😲... with 12 degrees of timing pulled for almost a second !!! Lol, yeah I think it's safe to say there's more there with the "R" manifold 👍... great work Randy Belehar
https://youtu.be/EI6RZv8lNzs
ID:	552578   Click image for larger version
ID:	552579   Click image for larger version
ID:	552580   Click image for larger version
ID:	552581   Click image for larger version
"DON'T BE A CV-1 HATER... IT JUST MAKES YOU LOOK STUPID"
Old 10-30-2020, 11:23 AM
Stan Weiss's Avatar
Hey Bill,
What times was Randy running with the low raise manifold? How much difference is there in runner length between the 2 manifolds?
Stan
Pontiac Pump Gas List
Old 10-30-2020, 02:07 PM
The other times lips in the pic the low rise manifold, I gotta dig up the runner lengths lol, that's not etched into the hard drive lol
Old 10-30-2020, 11:54 PM
... just saw the pic with the time slips wasn't there, i apologize ...
Old 10-31-2020, 09:50 AM
opeliac opeliac is offline
If that is the only change, it picked up a bunch of HP.
Old 10-31-2020, 12:12 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Alex Brooks did the swap on a dyno, if I recall it made around 30 hp more with the R manifold over the low rise
Old 10-31-2020, 01:31 PM
... the biggest change is the torque, i tested the R manifold on my 428 pump gas combo, it wasn't against the low rise manifold, it was the Blue Thunder Ford manifold i hacked up and made it fit the CV-1's, it gained 15hp over that but the really interesting change was where the peaks moved to, the R raised the HP peak 300rpm to 7300rpm and lowered the TQ 600rpm and made more TQ everywhere ... and in all of my testing and Darin Morgan's also, we've never seen that happen with a manifold before, maybe someone else has i'm not sure, but the bottom end below the torque peak was a massive increase, i actually pulled the 428 with both manifolds to the lowest rpm we could reach on the dyno and just kept turning up the servo until the engine gave up and started to stumble and break up under the load, the Blue Thunder started coughing about 3600rpm, the R manifold never coughed at all, no matter how low we pulled it down, or increased servo, it just stayed smooth and pulling, it was much stronger down there for sure ...
Name:	Bill's Cell Phone Stuff 2013-2017 3111.jpg
ID:	552671   Click image for larger version
Name:	Bill's Cell Phone Stuff 2013-2017 3112.jpg
Old 11-02-2020, 10:07 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
On the time slips...was the pass with the new intake first and then a quick change to the old intake or was it nearly 5 hours later going from heat of the day to cool of the night? Can’t tell whether that is a 3 or an 8 on the time stamp the way the photo was taken?
Old 11-02-2020, 05:35 PM
... well, if it was 8:58pm there wouldn't be sunlight in the photo of the time slips, it was about 45min between both runs, Randy started off with the R manifold first (9.25) and then switched to the lowrise ...
Old 11-03-2020, 08:49 AM
69Goat1's Avatar
Thank you for the answer...what sunlight are you referring to? You posted a bunch of photos and the only one you can tell was outside is his winner photo that was taken 10/29/20 but the time slip photos are 10/17/20...
Old 11-03-2020, 09:54 AM
...what sunlight are you referring to? .
"Only the shadow knows"
Appears he was facing north between 4pm and 6pm
Clay
Old 11-04-2020, 06:13 PM
... you are one seriously retarded individual lol .... Randy's results are 1000% legit, but it's no surprise you posted in this thread with your hater BS ... try again sir ... and the sunlight i'm refering to is the same that's shining on Randy's hand and the timeslips in the photograph ... duh
Old 11-04-2020, 06:14 PM
Clay
... stop it bro, the sun shines the same in Canada ...
Old 11-05-2020, 10:22 AM
69Goat1's Avatar
You can KMA! I asked an honest question and you immediately got snarky about sunlight...I have a shop and I can take a photo that looks just like yours inside it at night without trying and I am looking at all of this on a cell phone...so again you can KMAMF🖕🏽
Old 11-05-2020, 12:03 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Locking down thread in 3-2-1.......
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 11-05-2020, 01:19 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
It’s a coming!
Old 11-05-2020, 01:23 PM
slowbird's Avatar
slowbird slowbird is offline
Hope not, it good to see cv-1 results. Hope there are more to come.
Old 11-05-2020, 09:20 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by dragracerx2813 View Post
It’s a coming!
Nah ... First Paul K has to get involved.
Go fast, see Elvis!
Old 11-05-2020, 09:50 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
MOE, LARRY, CHEESE!
Old 11-06-2020, 07:42 AM
True story.
Closed Thread
