Interesting idea. My son is a CAD expert and also has a 3D printer. He has used a carbon fiber filament that might be strong enough. I think the issue might be whether it could be produced with enough precision. Thanks for the idea.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
These plastic parts are apparently made of nylon plastic, which is normally injection molded. My son is big into 3-d printing and explained 3-d printing nylon is very difficult and requires expensive printers that can shield the part being made in an airless environment. I had no idea there were so many types of plastic mediums. We're trying to replicate a wiring strap for "sanduner" that's made from nylon...and are trying different types of plastic. Just my take on the problem.
JK |
Can someone please confirm that on a '63 Tempest, the lower taillights are running/parking lights only, and the uppers are parking and stop/turn? I have a few electrical issues to sort out, and turn signal/brake lights is one of them.
Thank you.
Nevermind - I answered my own question when I actually pulled the lenses off and see the different size sockets and holes in the mounts.
I'm getting one done right now. Testing in progress. Hope to share soon in the Ropeshaft Reader.
Cool! I should be receiving the part I ordered within a day or two as well.
This looks encouraging! This part shows to fit a '63-'66 AMC Ambassador. It's a Sorensen part TP-111. There are others for Mopar and Ford that appear the same too. I hope to install tonight and test it.
Does the 37 amp alternator used on the 195 have a larger pulley than normal? Mine is larger than any V8 application I have seen. I have a bad flicker in my lights at idle, which does smooth out some when the RPM increases. I'm rebuilding the alternator now - it had a noisy bearing anyway, but I might try a smaller pulley too to increase the RPM.
There's in inherent defect in the electrical system on those '63 Tempests and Lemans in regards to charging the battery.. With the stock alternator and the metal can Delco voltage regulator. The Amp gauge in the dash is a full flow amp gauge; one wire on the backside of that gauge is yellow and the other one is red.
One wire goes to the "+" terminal at the starter solenoid which is wired via a cable directly to the battery and the other wire is bolted to the output lug at the back of the alternator. The connectors to that gauge are simply push-on tabs which don't actually transmit full current. Also those tabs are way too tiny in regards to the current flow at that location. When charging a run down battery or driving at night those tabs get pretty hot and will actually melt the plastic connector and then those 2 wires will melt. The push-on plug at that location I am sure was done for ease of assembly. Considering that all of the voltage that the entire car uses runs thru those 2 attachment points they should have been a pair of bolt on #10-24 lug connections instead of push-on. When driving at night all of the current that the headlamps are trying to pull is running thru those 2 push-on amp gauge connectors. On cars with 100,000 miles on them I have seen those brass tabs burned to the point where the amp gauge is ruined. There is a thin black cardboard insulator underneath both of those tabs; that cardboard deteriorates over time, and results in a direct short from the "+" terminal of the car's battery to ground. (That is what melts the red and yellow wires.) Those 2 tabs are wired to be 12 volts "live" constant; even if the car is just sitting, parked.
Peter Serio Owner, Precision Pontiac Last edited by Peter Serio; 09-19-2020 at 04:36 PM. |
There is actually a Pontiac dealership bulletin on those amp gauge plug-in tabs. When they went to "color key" the dash bezel at the assembly plant(s) the gauge cluster (including the bezel) came from AC Delco all put together. The assembly plants all had paint rooms and they had a special made 3D paper-mache cardboard "mask" that they used when they would paint the dash bezels. They used that 3D mask to cover over the front of the gauges but the rear, there never was any mask or covering for that. For that reason it is very common on many 1960s Pontiacs to see paint over-spray on the back side of the gauge housing(s).
The bulletin on the '63 Tempest addresses a possible complaint from a new car owner that his or her headlights show up as dim or that they flicker at night while driving at low speeds. The cure is to remove the dash cluster and flip that upside down on top of 2 or 3 clean shop towels set out on top of your workbench. You are looking for paint over-spray on the back of the gauges, specifically the 2 tabs at the backside of the amp gauge. Those 2 tabs would often be 1/2 way covered over with paint and the connection was not secure. Pontiac instructs that you take lacquer thinner and a shop rag and/or a tiny brass brush, or fine grade sandpaper and clean those 2 brass tabs. Then re-attach the connector.
Peter Serio Owner, Precision Pontiac |
Thread Tools | |
Display Modes | |
