Industry Stuff new repro's, updates, other info.
Old 08-05-2007, 06:06 PM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Default Need description of part/kit
Can you give a description or possibly a picture of PN RPC55 ? It is the Convertible Top Bleeder Kit. The 1966 Fisher Body Manual says to drill a 1/4" in a "spare" metal filler cap and solder in a copper tube. Solder needed to make airtight. Then use a piece of 3/16" rubber hose to run to a container of fluid for bleeding the system. It was printed back when you could go to the Pontiac Dealer and get a "spare" metal filler plug!
I would think that this kit has a filler plug with the tube built in and a length of hose? Would like to know before I order. Thanks! Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
Old 08-06-2007, 12:14 PM
dm_fan's Avatar
dm_fan dm_fan is offline
Administrator
We had one in stock so I took a picture.
Old 08-06-2007, 12:48 PM
66GTO Jim's Avatar
I'll take a look at the "filler plug" and see if this will do the trick. Thanks.. Jim
