Old 05-18-2024, 09:07 AM
JacintasHot's Avatar
JacintasHot JacintasHot is offline
Default SBC pushrods not spinning
On the 77 MC observed while diagnosing a miss at idle and a bog during initial light power takeoff. I'm assuming the cam is wiped. All I hear/ read about is how new cams are disintegrating left and right. Was told to "put in a roller". I'm like bull**** this is a passenger car cast pistons low compression 4800 revs max.
I'm willing to up the specs on a replacement a wee little bit but I do not want "camshaft failure" after replacing it due to "soft metal ".
Any ideas on a good flat tappet?
350 2 jet all original.
Hecho en China is not good for U.S.
Old 05-18-2024, 11:19 AM
Sorry I misstated the application should have posted "hydraulic lifter" not "flat tappet".
Old 05-18-2024, 05:11 PM
Make sure you run a oil with high levels of zinc.
https://www.speedwaymotors.com/the-t...reakdown/32479
I use STP.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 05-18-2024, 05:46 PM
67drake's Avatar
67drake 67drake is offline
I just broke in my bone stock ‘62 Mercury V8. I’ll be honest with you, I was nervous as heck for the same reasons.
I used Driven brand 10-40 break in oil, slathered Torco cam break in lube on cam and lifters, pre lubed engine with drill till I had oil at all 16 rockers, as my son slowly turned the engine over by hand. Stactic timed it when I dropped the distributor in, filled the carb float bowl, dribbled some gas down the throat too. Fired instantly, and all is well.
I honestly am going to get my next cam and lifters treated before I install them. I forgot the name of the process, but it’s just such a roll of the dice these days. There is a few threads here on the treatment process, and it’s not cheap, but I don’t have time or money for a redo either.
My plan is to pull the cam out of my ‘63 LeMans next winter.
Good luck.
‘55 Catalina
Old 05-18-2024, 06:19 PM
77 TRASHCAN's Avatar
The best replacement cam for nearly all stock applications is the Sealed Power CS274, period!!!
Shut it off
Shut it off
Old 05-18-2024, 08:16 PM
694.1 694.1 is offline
Nearly everything I have read imply that is the poor lifters, not cams or oil.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 05-18-2024, 09:00 PM
Unavailable all over on that sealed power
