Old 08-28-2023, 01:18 PM
55Wagon 55Wagon is offline
Default Dumping canister oil filter for spin on
Hello, I am going to replace my canister oil filter, and replace it with a later model spin on filter. Do I need to change anything or just bolt it on?
The reason I ask is canister pressure spring retainer has 1/4 Dia hole, and later model one does not. Thanks.
Old 08-28-2023, 03:37 PM
Bill Hanlon's Avatar
I put the filter mount from a '77 400cid Pontiac V8 on my '57. Worked great. Note that there are 3 types of filter mounts. One mounts the filter straight down and is what I got from the '77. One slants the bottom of the filter slightly towards the oil pan. The third I've never seen. It slants the bottom of the filter towards the rear of the car. All use the same gasket to mount to the block as does your original. I used NAPA Gold 1049 spin-on filters.
Old 08-28-2023, 11:46 PM
Thanks Bill, mine is the straight down version. I will get it bolted on in the morning.
Old 10-28-2023, 03:40 PM
INchief INchief is offline
Default 55 287
Is there one you could recommend using for a 55 287? I want to change to the spin on filter, but have been able to find an adapter to replace the original.
The Following User Says Thank You to INchief For This Useful Post:
Old 10-28-2023, 04:53 PM
Pictures and information here on which spin-on filter adapters you can use on ‘55 - ‘60 engines:
https://forums.maxperformanceinc.com...&postcount=115
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 10-28-2023, 06:43 PM
I used one from a 1963 that was pointed straight down on my 1955. That was over 30 years ago and has worked fine. Any one that points down should be fine.
The Following 2 Users Say Thank You to Goatracer1 For This Useful Post:
Old 11-20-2023, 04:20 PM
61 vent 61 vent is offline
Just what Bill said, Minre went right into place, I used the straight-down version. I am sorry I can't give any other information. I bought mine from a buddy in Az.
The Following User Says Thank You to 61 vent For This Useful Post:
Old 11-22-2023, 10:43 AM
Default Searching the internet now
No problem, I'm searching the internet (the usual suspects). I'm sure I can find one that will work. Cheers!
Old 11-22-2023, 05:53 PM
I have several.
Old 11-24-2023, 04:26 PM
Default Oil Canister
Originally Posted by Goatracer1 View Post
I have several.
OK, I'll send you a PM. Thanks
Old 11-28-2023, 12:36 PM
INchief never heard back. Are you still interested?
