400vs455 stroker
Which is going to make for a faster car. I have a 400 bored .60 over 85cc Kauffman heads, old faithful cam ported and matched at SD Performance. The heads were done up for a 455 but we put them on the 400. Now I found a 455 block and can get it cleaned up at .30 over buy a 467 Butler balanced rotating assembly and bits for $2500. My buddy says it won’t make for a better faster car... what do you think?
Sent from my iPhone using Tapatalk |
Someone once said, several decades ago: there is no substitute for cubic inches.
Still true today. |
X2 no replacement for displacement
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Yeah, it would not only have more cubes/stroke/torque, But also more compression. Would make lots more hp/torque.
While not a Apple to Apple comparison, I went from a 4" stroke to a 4.050" stroke, and from a .030 overbore to a .060 over bore. Same heads, cam, intake etc. Car picked up 2 tenths in the 1/4.
The 467 Stroker makes a great street/race engine. If you can pick one up for the price makes it a no brainer.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
Because smaller journal engines are stronger in the main journal area, wouldn't the best option be to stroke the 400?
But, because of price, a 455 MIGHT be the "best option", IF you can find a good 455 block & crank to use, for a reasonable price. A forged crank stroker assembly, for a 400 block, is over $2000. https://butlerperformance.com/i-2445...tegory:1459542 So, one would have to compare the cost of a stock crank 455 build vs a forged crank 400 block stroker build. Then, they'd have to decide if they think the 455 would hold up, for the rpm they plan to go. Unless it's some sort of high rpm racing engine, I don't think the larger 455 mains are a problem. And some have posted that the factory 455 crank is good for 500hp or more. We made many hundreds of drag strip passes with my homebuilt cast rod 455 bracket engines. Never had any bearing or other shortblock problems. Shifted at 5000 rpm, with rev limiter set at 5500. Last edited by ponyakr; 09-24-2019 at 11:12 AM. |
I would just use your 400 block and buy a stroker kit for it. same cubic inches and you dont need a new block.
Shawn 1971 Formula #s match white/tan 1973 TA Brewster/white #s match 1972 Buick GS455 #s match 69k miles now a 470 stroker. 1986 Buick Ttype 66K miles many mods 10 sec street car. 2001 Mustang gt premium vert. Mamas car |
The 3.25 Mains are not a problem. I run 421/428 blocks with a 4.050 crank to 7200RPM averaging 150 to 200 passes a year. Keep the rods and main clearances in check and there should be no problem.
I just reread the post and looks like he is buying a new stroker kit??? If the engine is not numbers matching, and is a earlier model block I would just stroke the 400 you currently have to 4.250.
