Old 09-30-2019, 05:53 AM
chuckies76ta's Avatar
Default Headers size
Hi: What size headers would be required to support a 750 hp engine? Round port.
Looking at a set of Doug's 1-7/8" for a 68 Firebird.
Also wondering if they will fit a 68 Firebird?
https://butlerperformance.com/i-2445...tegory:1234810
Old 09-30-2019, 06:05 AM
Here's some base line info for you.
The main concern before Exh flow numbers though is that the inlet to the header tube is bigger then the Exh port outlet flange size by atleast 1/16" and preferably 1/8", especially on the floor of the port which is not a issue if the round ports are the better working D shaped version .
How many cid is the motor?
Old 09-30-2019, 08:44 AM
slowbird's Avatar
slowbird slowbird is offline
That graph os useless in my opinion. If you follow that graph then ci and rpm jave nothing to do with exhaust size. According to that graph our GTO should be running roughly 1 3/4" headers, the car was 2tenths slower with that size header vs 2".
Old 09-30-2019, 09:02 AM
grandville455's Avatar
Chuck I am running 1 7/8 on my pos
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 09-30-2019, 09:07 AM
PAUL K's Avatar
PAUL K PAUL K is offline
That's probably the problem
Go fast, see Elvis!
Old 09-30-2019, 09:31 AM
Gary H's Avatar
Gary H Gary H is offline
Personally I think 1 7/8" headers are going to be marginal for 750 HP. A few years back I dyno'd a ~ 550 HP engine that was 461". We initial used 1 5/8" headers because he was going to use Ram Air manifolds on it in the car and we thought they would be similar in flow. After getting a base number, we swapped to 1 3/4" headers and the engine picked up 18 HP. I think at 750 HP you would be giving up some power versus 2" tubes. Just a fyi, I recently built a 535" that made 872 HP and we used 2" headers. Myself, I run stepped headers 2 1/8' to 2 1/4". Engine made 1039 HP
Old 09-30-2019, 09:33 AM
Steve C. Steve C. is offline
I don't know how useless it is but that formula posted above was published by David Vizard. As many know much of his work has been centered around Chevy engines, especially the 350cid. Therefore I've often wondered if it might be canted in that direction.
That said I've taken note of it and worked the formula around my Edelbrock heads and with porting the exhaust port ended up towards 250 cfm at the upper lifts. As noted David's formula is based on the INSIDE diameter. I run 2-inch headers (outside diameter) on my 505 that makes peak power at 6000 rpm.
Here is another one below that tends to back that up.
How Header Primary-Tube Diameter Affects Performance ?
Tech article from Hot Rod magazine:
https://www.hotrod.com/articles/head...s-performance/
2-inch outside diameter less a typical wall thickness.
Example- 16 guage = .062" x 2 = .124
or 1.876" inside
Old information here:
Old 09-30-2019, 10:57 AM
You reply that way every time I post up that info slowbird so why don't you post up your guide lines and be more helpful.
Old 09-30-2019, 11:17 AM
slowbird's Avatar
Buy pipemax, very cheap software, tons of info, and will not lead you down the wrong path. No header builder that i've talked to has ever asked me for exhaust flow numbers.
Old 10-01-2019, 06:11 AM
Paul, LMAO!
Darby
Old 10-01-2019, 07:08 AM
Thanks guys..
Charles
Old 10-01-2019, 08:24 AM
Correct. EXH travel length & ID for best "CFM" (try CFS) is thermal-dependant.
The thermal dependancy is CSA & Length dependent. These tings show up as EXH velocity vs travel length.
Id be keen to see a plot of EXH dia vs RPM for best ET. Could be an eye-opener.
Old 10-02-2019, 06:49 PM
bluegoat65 bluegoat65 is offline
I like the Wallace racing calculators.
