Old 10-08-2019, 09:55 PM
Hooter's Avatar
Hooter Hooter is offline
Default Biggest Stroke IA2 Std Cam Tunnel
I have a tall deck IA2(11.00 deck height) with standard height cam tunnel. For future reference, what’s the biggest arm that will fit in it? I had less than stellar results(piston scuffing) with a 4.75 stroke in a standard deck height motor, but have more room to work with on this motor. No immediate build plans, but the recent post on a 4.5 stroke crank got me thinking about this again. The torque on the street with the 4.75 crank was unreal. Like to go bigger if possible. Will run steel rods.
67 Bonneville ragtop
Old 10-08-2019, 10:23 PM
John Langer's Avatar
John Langer John Langer is offline
Depends on what diameter cam you run...
Old 10-08-2019, 10:24 PM
Hooter's Avatar
55mm
Old 10-09-2019, 12:58 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Throw away the cam. Get busy designing/building OHC Pontiac heads.
Old 10-09-2019, 09:52 AM
Hooter's Avatar
I’ll get right on that Jack lol.
Old 10-11-2019, 11:20 AM
Hooter's Avatar
Bumparoo.
Old 10-11-2019, 12:02 PM
Run boost out of something for more torque with less CID which will also save you the top end HP loss from the added friction of those long NA stroke motors.
A scant 8 psi of boost will leave relling from the torque production level!
Old 10-11-2019, 03:55 PM
Dragncar Dragncar is offline
Bumparoo.
"Bumparoo" in the "Race " section ? Never seen that one.
Old 10-11-2019, 10:49 PM
4.750, maybe 4.800. A lot depends on the counter weights of the crank and the skirt of the piston vs the crank and the counter weights and rods to the cam. Tough question to answer.
Old 10-12-2019, 12:10 AM
slowbird's Avatar
slowbird slowbird is offline
Interesting i thought all tall decks had a raised cam location.
Old 10-12-2019, 07:53 AM
Hooter's Avatar
When I ran the 4.75 crank with 6.7 rods in my old motor, I had to cut the counterweights down to clear the piston skirts. Had the std size cam tunnel. Skirt clearance won’t be problem in this motor with the ability to run a longer rod. Cam clearance seems to be the big concern.
