Old 10-14-2019, 07:08 AM
gto65 gto65 is offline
Default SD Performance
Looking to get a set of cast iron heads ported. Not sure what SD Performance is doing. Tried for the last two weeks to contact them, no response. Is Dave Bishop still in business. Had them do some head work for me in the past, very satisfied. If there out of buisnes who are the leaders in cylinder head work.
thanks
Old 10-14-2019, 08:35 AM
Mike Davis's Avatar
I believe they are still in business. I tried to contact them for 3 months, Emailed numerous times and left quite a few messages. Never heard back from anyone.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-14-2019, 08:50 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Good luck! I tried for quite a while to get a Stump Puller cam. No luck for me.
Old 10-14-2019, 08:53 AM
slowbird's Avatar
slowbird slowbird is offline
If you're interested in someone else porting them, contact Paul K. He can do them for you.
Old 10-14-2019, 09:03 AM
Tom Slawco Racing heads knows these Iron heads. He did my 48s while at Brandywine CYL Heads.
His CNC shop is in Maple Grove (Morgantown) PA
Old 10-14-2019, 12:12 PM
Dragncar Dragncar is offline
He is still in business. E mail is the best way. He is a one man deal so its rough on him.
Got my High Ports back from him a couple months back. He did a set of 48s for me years ago. They went 272cfm, no epoxy.
Dave Wilcox does iron heads. He can get you 300cfm, but I bet you get epoxy. He can do smaller ports without it.
If you want me to get ahold of Dave for you I will give it a shot. He gets back to me, might take a couple days though.
Old 10-14-2019, 05:05 PM
pastry_chef's Avatar
https://headsandmanifolds.wordpress....-head-porting/
Old 10-14-2019, 05:18 PM
Lee's Avatar
Lee Lee is offline
Dave has been sick. I think it started as a cold about 3 weeks ago, he tried to work through it and it got worse. He got back to the shop last week, but I think he missed most, if not all, of the week before. He is trying to get caught up!
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 10-14-2019, 06:07 PM
By the time you buy all new stuff and do them right with the cost of port work your right there with new aluminum heads. More modern combustion chamber and loss of nose weight. It's tough not to pull the trigger. I do my own porting and it's not hard to hit 250 at .550 the other 20 is time consuming and things start to get thin in places.
Old 10-14-2019, 07:02 PM
Smile
thank you for all the input.
Ill try e mailing Dave.
This! When I built the 455 going in the 81 it came with some well ported 6Xs. Tossing those heavy suckers on the flowbench to compare them to some out of the box Edebrock heads that flowed as good and were WAY lighter made the choice for me.
Old 10-14-2019, 08:39 PM
There are many options beyond S.D. a local shop could do a fine job as long as they are a reputable shop... heads are heads... you dont need a "PONTIAC" shop for induction....
Old 10-14-2019, 09:44 PM
performerrpm's Avatar
he still in buisness, i just got my 72cc now 96cc eheads back like 2 weeks ago. turn around times alot longer just being him tho. email is best. uptil time to pay our whole deal was done thru email
Old 10-15-2019, 04:25 AM
Drag Star Le Mans's Avatar
I heard he was out at Mission Raceway last Friday. His kid was running a 78 Trans Am in the low 12s. This next Saturday is the last test and tune at Mission and I hope to get up there weather permitting? I'm sure he will be there. And like the others have said he is still in business.
DragStarLeMans
Old 10-15-2019, 09:13 AM
gassman_67's Avatar
gassman_67 gassman_67 is offline
I tried also to get a hold of SD....I gave up and gave my business to Jeff Kauffman, they respond to email and phone calls.
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
Old 10-15-2019, 02:54 PM
MescaBug's Avatar
MescaBug MescaBug is offline
Sent Dave an email, got a reply 12 hours later. They are still in business, and usually respond within 24 hours.
Sometimes emails will get in to the Junk folder... Just a thought.
Old 10-15-2019, 06:17 PM
mgarblik mgarblik is offline
Nothing against Dave at SD or anyone else who ports ancient Pontiac iron
...........but wouldn't it be sooooooo nice to open a box and pull out a pair of NEW IRON Pontiac heads with flow numbers equivalent to ancient ported heads for about $800.00 to $1000.00 less a pair ? Any vendors listening out there?
Old 10-15-2019, 06:28 PM
77 TRASHCAN's Avatar
I'm on board with you there!!! World products needs a bunch of us Pontiac'ers pestering the crap out of them about this!!! A set of "D" ports that could out flow even RAIV's would be good to start with!!' Might put the hurt on the alum head folks!!!
Shut it off
Shut it off
Old 10-15-2019, 08:59 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Dave is down to just him?
What about Marcel?
Goatzilla racing was talking about (possibly) casting a new iron head.
Old 10-15-2019, 09:15 PM
Did I mention you dont need a "Pontiac" shop to do heads.... a port is a port no matter what color you paint the head....
This isn't that complicated...
