Old 01-25-2010, 10:10 PM
tom s tom s is offline
intake,carbs and heads when they were on my alu block in my 63 Lemans.Tom
Old 01-26-2010, 12:25 PM
found out Joes used a Quickfuel 1050 for the single 4 pulls.The 2 750s made 35 HP over the 1050.Tom
Old 02-02-2010, 09:51 PM
pic of the engine,the block casting number and the single 4 intake that SD did to run on the KRE heads.Tom
ID:	196012   Click image for larger version
ID:	196013   Click image for larger version
ID:	196014   Click image for larger version
ID:	196015   Click image for larger version
Old 02-03-2010, 11:58 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So was that a 1050 -4150 type carb or a dominator style?
Still hard to beat a dual quad look for me esp a bathtub-but then I'm an old 409 dual quad guy!
Skip Fix
Old 02-03-2010, 04:13 PM
4150 base.Is that the block you were interested in?Tom
Old 02-03-2010, 05:16 PM
steve's Avatar
steve steve is offline
nice to see some other 557 blocks out there at or over 500HP !
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 02-03-2010, 05:37 PM
Kyflier Kyflier is offline
I have 2 557's in my garage, if someone is in need of a block. I mean one, cause is in my car lol....I forgot...
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 02-03-2010, 08:43 PM
Skip Fix's Avatar
Yep that is the "weak" block.
Skip Fix
Old 02-03-2010, 11:32 PM
this motor,IF ever put in a car wont see over 3000 RPMs anyway.Tom
Old 02-04-2010, 12:17 AM
ta man ta man is offline
3000rpm?
Old 02-04-2010, 12:20 AM
4 speed,idle to 3K,shift,go to 3K,shift etc etc.Tom
Old 02-04-2010, 12:51 AM
Why have the good heads and roller cam then?Nice to see all the horsepower it has but why not drive it hard once in a well?Seems like a waste of parts might as well have a stocker in the car.
Old 02-04-2010, 12:49 PM
was just old used and cheap stuff I had laying around.May not ever go in a car!Just around incase I want to sell my 69 bird and wont want to let the short deck RA V engine go with it.Like I said,a throwaway engine.BUT a nice one!Tom
Old 02-04-2010, 01:25 PM
theYman's Avatar
theYman theYman is offline
Your "throw away" engines are nicer than most peoples "hard earned money" engines!
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
Old 09-20-2010, 08:27 AM
elefantrider's Avatar
elefantrider elefantrider is offline
How cheap is cheap? How much money do you have in just assembly/machine work/dyno time on this throwaway engine?
Old 09-20-2010, 08:57 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
What is, or was, the 4 bbl manifold? I can't make out the markings from the pic.
Just curious, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 09-20-2010, 09:30 AM
the intake is a 62-63 421 SD NASCAR 4 bbl intake that has been converted to late heads.It is on my 63 421 cat with #64 heads as we speak(ot type).Tom
  #38
Old 09-20-2010, 09:45 AM
Murf'sDad's Avatar
Thanx Tom. You can see the design similarities in the later 68-72 manifolds.
Stewart
  #39
Old 09-20-2010, 03:26 PM
the RA IV intake was a takeoff from it.Tom
  #40
Old 09-20-2010, 05:54 PM
David Holmberg's Avatar
Tom, is that the intake (NASCAR) that uses the really long back bolt?
Great numbers, will make a really nice driver motor if/when needed.
