Old 11-15-2011, 08:19 PM
brut4s's Avatar
brut4s brut4s is offline
Any updates?
  #82
Old 11-16-2011, 10:24 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
Originally Posted by brut4s View Post
Any updates?
+1! I am salivating about this build What do you expect to put down to the wheels? And can you post when you plan to take it to NED? I want to be there to see it make a pass
Panos
Little Miss G Racing
  #83
Old 11-16-2011, 01:40 PM
cgeise's Avatar
cgeise cgeise is offline
BTW - Are you guys planning on running a full data system?? I HIGHLY recomend it.
  #84
Old 11-16-2011, 03:44 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
This engine should have been on the dyno already. Tom Vaught's help and Ed Page's patience has been great. We have had things that cause a delay due to this being our first Turbo build. For example, neither Tony nor I had any relationship set up for purchasing these injectors. Since we dont normally like to pay retail, it is a tough pill to swallow when we do.
We are now waiting on the fabrications department on intercooler, headers, and cold side. I cant get a firm commitment on the 4500 series air bonnet. Will try that this afternoon. Casey and I are going to the fab shop on firday to figure out all our final strategy. I am also going to BES Th or F to get progress on the engine build. I will try to get pictures.
We are using the Dominator Controller from Holley Cg, I think you will find that more than satisfactory. It has full capability along with electronic transmission control. It also have drive by wire, but I dont think Ed wants to do that until Holley has more experience with it.
Side note, Caseys SuperCoupe turbo Tbird 3.8L V6 has a best of 820 RWHP and 805 Torque on a college shoe string budget street engine!
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
www.ChemicalManagementIndiana.com
317-260-3486
  #85
Old 11-16-2011, 07:39 PM
cgeise's Avatar
any and all info is good info --
  #86
Old 11-16-2011, 08:01 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Curt,
In your opinion, what’s the bare minimum we should be monitoring?
The Holley Dominator ECU supports quite a few inputs.
20 high side (+12v) PWM or switched outputs
16 low side (ground) PWM or switched outputs
6 speed inputs (magnetic or hall effect)
30 0-5v sensor inputs
13 Multi-inputs
Each header tube has an EGT bung, there should also be an additional bung installed in the collector and 1 before the T6 flange to monitor back pressure.
I believe we have the following sensors:
2 NTK O2 Sensors
2 3 Bar Map Sensors
2 Air Temp Sensors
2 100PSI transducer
1 Coolent Sensor
  #87
Old 11-16-2011, 08:51 PM
cgeise's Avatar
Racepak makes an interface that will take all the info from the EFI module and record it in the racepak a driveline sensor is important and if your using a boost control - record that, fuel pressure, I also read pan vaccum. Dont put the O2 sensor to close to the turbo outlet - it changes the readings. Thas enough to get you in trouble - -lol
  #88
Old 11-17-2011, 12:22 AM
RAIV-Z's Avatar
Holley Dominator EFI has internal data-logging standard with 2GB of memory as well as boost control based on time, gear, speed, etc..
Was that crankcase vacuum?
Is there a rule of thumb for O2 sensor placement distance from the turbo outlet? I looked at innovate motor sports manuals for their wideband sensors and they claim the temp at the bung should not exceed 500c or 900f.
  #89
Old 11-17-2011, 12:59 AM
Monitor boost to backpressure too. Positive delta(boost higher than backpressure) good negative not so good. Strive for 1:1 or better. Not easy many never get there, but if power isnt what you feel it should be for the boost its the first place to look unless you have other obvious problem. Once its right(at some point you decide you got all you got) you probably wont look at it directly.
  #90
Old 11-17-2011, 10:08 AM
12" minimum from turbo outlet should work fine. Also, having it before any couplings in the exhaust system will insure no outside air will pollute the readings in case of a leak at that coupling. Lastly, they should be installed at roughly 10 or 2 o'clock position.
Panos
  #91
Old 11-17-2011, 01:40 PM
cgeise's Avatar
Yes - -crank case vacuum -- As Im not familure with the Holley ECU - are you saying it can control waste gates? and if so how ??
  #92
Old 11-17-2011, 04:19 PM
RAIV-Z's Avatar
Yes, the Holley Boost control is currenty under beta test. They will use an electronic solenid to control the wastegates.
  #93
Old 11-18-2011, 09:51 PM
RAIV-Z's Avatar
Default Picked up a T400 Transmission
Case only...
I needed one for the mockup, getting the 69Bird ready to send it off to the chassis shop to get it cut up.
Anyone have a first gen Bird for sale setup to handle at least 1600hp, send me a PM.
Thanks.
  #94
Old 11-22-2011, 12:27 PM
RAIV-Z's Avatar
Mock-up engine and turbo400 transmission installed in the 69bird last weekend. Thanks Polar-Pontiac for sending over some links to potential candidates. That 68 in Texas is a beautiful car, if only I had a few sponsors…
http://trailerjunk.com/Top-Sportsman...ER-OR-T-K.html
IA-II shortblock assembled. RA-V heads not quite done yet.
ID:	264496   Click image for larger version
  #95
Old 11-24-2011, 11:49 AM
67'7F6'Bird's Avatar
Hi,
Do you have any pictures without the engine block diaper?
Why are the head studs different color?
Please post pictures of the piston dish before the heads are bolted on.
Thanks, Looking Good!!!!
Steve
  #96
Old 12-07-2011, 09:42 PM
It shouldnt be long now! What a street engine! Thanks to Ed Page, BES, Turbonetics, and a big thanks to Tom Vaught!
Name:	finished engine.jpg
ID:	266235   Click image for larger version
ID:	266236   Click image for larger version
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
317-260-3486
  #97
Old 12-07-2011, 09:44 PM
mysticmissle's Avatar
looks great ed. im sure the wait will be worth it!
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #98
Old 12-07-2011, 10:17 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by NHRASuperStock455SD View Post
It shouldn't be long now! What a street engine!
Agree! A Very Fine RA-V Engine ready to make some SERIOUS POWER.
Tom Vaught
  #99
Old 12-07-2011, 10:55 PM
shaker455's Avatar
shaker455 shaker455 is offline
Great! whens it going to the dyno?
Carburetor building & modification services
Servicing the Pontiac community over 20 years
  #100
Old 12-07-2011, 11:01 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default just awsome
Looks great!!!!!!!!!! cant wait to see it in a car and running!!!!!!!!
