Old 08-27-2017, 11:40 AM
njsteve's Avatar
njsteve njsteve is offline
Default 2001 WS6, 6-Speed, Black, T-Tops, 63,000 miles for sale
2001 WS6 Trans Am with a 6-speed manual transmission. Black with ebony leather interior. 63,640 documented miles. Original born-with engine, T56 transmission and rear. I purchased it in 2014 from the original owner, who bought it new in Cinnaminson, New Jersey. Being a maintenance fanatic, she purchased 15 years of GM extended warranties on the car and it was dealer maintained up into 2016! I have every piece of original paperwork on the car – window sticker, invoice, and a ¾ inch thick, stack of GM receipts from day one to this year.
It is a real WS6 car with the confirmation letter from ASC indicating it is one of 1,583 Black, WS6’s with T-Tops and a 6 speed, made in 2001.
The WS6 was an upgrade from the Trans Am (similar to the Camaro SS). The cars were shipped from the assembly line to ASC where they were upgraded and then shipped to the receiving dealers. The WS6 package included the Ram Air hood, matching air cleaner, upgraded suspension, power steering cooler, 17” wheels with 275/40R17 tires and free flowing dual exhaust. Other options on this car are the factory installed Hurst shifter, traction control, and custom leather buckets. The original sticker price was $32,070 in 2001.
The only thing that differs from stock is a Magna Flow muffler that the original owner added. In perusing the 16 years of service records, the items replaced have been a door speaker, the alternator, various idler pulleys, one catalytic converter, the steering rack, power steering pump and hoses, and the rear differential was rebuilt and the bearings were replaced. All of this was done by GM dealers under warranty with only GM parts.
Things I have done to the car since I bought it in 2014: I changed the original plugs and wires (All original parts have been saved and go with the car). The plugs were burning perfectly as you can see in the photo. I replaced the carpet, which was heavily stained with years of spilled coffee marks. I also replaced the driver’s door panel (which had the typical crack at the top) with a perfect door panel. I also had the outer sail panel removed and replaced with a sail panel from a prior year Trans Am. (GM had a major issue with a faulty adhesive used on the assembly line to attach the sail panels on the Camaros and Firebirds from 1999 onward: after several years, the adhesive would eat through the plastic body panel and cause blisters in the plastic and paint. A technical service bulletin detailed the extensive process and parts needed to replace the panel properly. Had the original owner known of this “secret recall” she would have definitely had it done by the dealer – but they never volunteered the information while she had the car.
The car runs, drives, and handles beautifully. Everything works including the power antenna. Very tight and crisp performance from the 63,000 mile, Ram Air, 325 horsepower LS1 and 3.42 rear end ratio. The original clutch works perfectly with no noises from the throw-out bearing. The original owner was an over-the-road truck driver and knew how to drive a stick! She was a very cool lady, indeed.
The 6-speed WS6 cars are extremely hard to find – the majority you see for sale are automatics. It is even harder to find one that had not been modified and beaten to death. This car is a very nice, unmolested example and you will not be disappointed.
$16,000.
The car is here in central New Jersey. Full VIN available on request including block VIN photo which was a doozy to get - I had to use a mirror and photograph it in reverse - it is nearly impossible to get access to!
Thanks, Steve
PM me here and I will respond back ASAP.
(larger MB photos are posted here: http://www.yenko.net/forum/showthrea...95#post1365395 )
ID:	462103   Click image for larger version
ID:	462104   Click image for larger version
ID:	462106   Click image for larger version
ID:	462107   Click image for larger version
Old 08-27-2017, 11:41 AM
njsteve's Avatar
Engine and interior photos:
ID:	462109   Click image for larger version
ID:	462110   Click image for larger version
ID:	462111   Click image for larger version
ID:	462112   Click image for larger version
Old 08-27-2017, 11:42 AM
njsteve's Avatar
Underside:
ID:	462114   Click image for larger version
ID:	462115   Click image for larger version
ID:	462116   Click image for larger version
ID:	462117   Click image for larger version
Old 08-27-2017, 11:43 AM
njsteve's Avatar
More photos:
ID:	462119   Click image for larger version
ID:	462120   Click image for larger version
ID:	462121   Click image for larger version
ID:	462122   Click image for larger version
Old 08-27-2017, 11:44 AM
njsteve's Avatar
Paperwork, etc,
Name:	window sticker.jpg
ID:	462124   Click image for larger version
Name:	ASC letter 1.jpg
ID:	462125   Click image for larger version
Old 09-01-2017, 07:45 PM
njsteve's Avatar
Full set of the factory 2001 GM Service Manuals go with it. (Jack Russell not included)
Old 09-01-2017, 11:40 PM
unruhjonny's Avatar
WOW!!!
Someone's getiing a GREAT car!!
glws!!
1970 Formula 400
Old 10-28-2017, 11:55 AM
njsteve's Avatar
Price reduced: $15,000. Great running car and just passed NJ emission inspection with flying colors.
Old 01-04-2018, 01:24 AM
MD79TA MD79TA is offline
Default 2001
Is it still for sale?
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 01-04-2018, 01:29 AM
njsteve's Avatar
Yes, she is.
Old 01-19-2018, 12:34 AM
takid455 takid455 is offline
Send a message via AIM to takid455
Remember when you first got this. Nice car in person too. IF it wasn't for the new house, I would be on it.
Old 02-27-2018, 08:10 PM
njsteve's Avatar
Still for sale. Ready to come out of winter hibernation. It's a great car with bulletproof paperwork and service records from day one to today.
Old 05-25-2018, 01:20 PM
njsteve's Avatar
The WS6 is sold!
