1969 RAIV value ?
Guys, I need some help on the value of a 1969 RA IV that is complete from Carb to oil pan. I don't know the condition of it at this time, but would like to get a feel for the numbers before it is looked at for value.
Please give me your estimate from bad condition to very good.condition. Thanks, Jim |
It will always be worth more to someone restoring a car. And even more if the date codes work for a specific car.
My guess would be 3k-10k. Assuming: correct carb, distributor, intake etc. |
Please note that for the RA4 heads to be production original the machining for the center head bolt under the valve cover will be seen to have wiped out 80% of the casting date pad.
This would have a huge impact on the worth of the heads if they where purchased over the parts counter!
Carb is worth $3500. Heads $3000. Intake $750. Block $3500. Figure in the other parts.
As someone mentioned if you find the car that belongs in could bring huge money!
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
I would think your more likely to get more money separating it. But people would also call you names for that. I might take less money and keep the whole thing intact. Sleep better at night.
15 to 20k if everything there is correct and complete.
Also condition is everything .. You have to question why was it taken out of service car wreck or spun bearing dropped valve .. I wouldn't pony up serious money for the short block without looking under the oil pan and valve covers while rotating
1969 RAIV value ?
Any idea of what the engine came out of?
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
Depends if it's from a gto or a firebird
Makes a big difference price wise.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
If it's an SR block will also effect value. Would to see if there is a VIN on the block, what the casting date is, date on the carb. A lot of the "original" 7028273 manual carbs are clones. I think the auto carb also brings less money. I agree if it's all original and correct it would be worth strong money to the person with the car it came out of
Did I miss if its a auto or stick shift engine?A stick shift carb is worth way more than a auto.The code on the block would really help also.Tom
WW is the manual engine code XP is the automatic engine code |
Thread Tools | |
Display Modes | |
