Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 10-24-2017, 03:34 PM
Anthony Anthony is offline
Default Hood tach inop
So I'm on the second good tach and its not working right either. If the car sits in the sun for a while when you start the car the tach does not work if you gently tap the tach housing it will then work. Also it's off by about 300 rpm. I'm so sorry I cut a hole in my hood for this junk.
Anthony
Old 10-24-2017, 04:46 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Athony,
Please contact us @ 1-800-421-2637.. This is not a typical issue with the tachs we offer, we will gladly try and help you out any way we can!
Old 05-27-2019, 07:06 AM
F ROCK's Avatar
F ROCK F ROCK is offline
same here.
My PY hood tach died after a very short time. Mr. Cass stepped in and had mine repaired after the ames merge but it died again after very few miles and I too wish i'd never cut a hole in a somewhat rare and VERY expensive steel 1971 GTO hood. no rain or weather involved but that really shouldn't make a difference. My hood is closed very gently.
bad product there.
Old 05-28-2019, 08:40 AM
AMES-TECH's Avatar
Originally Posted by F ROCK View Post
same here.
bad product there.
Have you attempted to contact us after the second defect? There is a manufacturer's warranty on these hood tachs, and we are always willing to help.
[/SIGPIC]
Old 05-28-2019, 08:56 AM
tempest1964's Avatar
Sometimes people get fed up and disgusted after multiple failures.....
Old 05-28-2019, 09:34 AM
AMES-TECH's Avatar
Understandable, but it will always help to contact us. Although he might not want a replacement, we are still able to help the customer and attempt to better the situation.
[/SIGPIC]
Old 05-28-2019, 12:25 PM
Copy that
Old 06-07-2019, 02:31 AM
F ROCK's Avatar
after three years, I doubt you were going to do much; and after TWO bad units; I went back and installed the tach that I was trying to replace. it sticks sometimes, but at least it works.
I made yours into a clock.
Thread Tools
Display Modes
Smilies are Off
