Old 02-25-2018, 06:14 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 65 Tire and Wheel Disc Details
Tires and Tire Valve Extension.
When I purchased my 65 it came with several original items that had been removed at some point stashed in a box. Thankfully the Original owner choose to save this stuff.
Also in the console glove box were two “tire valve extensions”.
After some research I learned this vehicle was to have these 1.09 (1-3/32) #9417730 extensions for the Wire Wheel Disc the car was ordered with.
I recently mounted the proper 7.75 x 14 BFG Silvertown 1’’ white side wall tires with 4 of these extensions (schrader with the metal ball tip). The Wire Disc fit very nice over these extensions just as designed.
I have to say the Reproduction BFG Tires are very close to the Original Spare that’s in the trunk.
First photo is the Repro tire and the second photo is the OEM Spare tire.
ID:	476606   Click image for larger version
ID:	476607   Click image for larger version
ID:	476608   Click image for larger version
ID:	476609   Click image for larger version
Old 02-25-2018, 06:19 PM
60sstuff's Avatar
Default Details Details
Mounted up and looking like they should.
Note, check the date on the wheels 9 - 64.
Chris.
ID:	476612   Click image for larger version
ID:	476613   Click image for larger version
Old 02-26-2018, 09:11 AM
Andre's Avatar
Andre Andre is offline
Coincidentally I am getting ready to put a set of near NOS wheel covers like this on my '64 convertible. I was doing some research on the valve stem extenders, and I couldn't find any data, but it seemed like for '64 at least the extenders were needed for this cover and the spinner cover. Poverty cap would not need an extender.
I wondered if all wheels/tire were assembled with a standard length valve, then extenders added as needed. I suppose they would have shipped in the trunk with the wheel covers for the dealer to install?
Old 02-26-2018, 07:30 PM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
My '65 came with Deluxe Wheel Discs. These also use an extension, #9417466, which is 1.59" long. The extensions say "SCHRADER USA" and have the metal tip. The tires are reproduction Firestone Deluxe Champion 7.75-14.
ID:	476693   Click image for larger version
ID:	476697   Click image for larger version
ID:	476698   Click image for larger version
Old 03-01-2018, 08:21 PM
60sstuff's Avatar
Default Factory Wheel Disc
Todd,
Your GTO with the factory “Deluxe Wheel Disc” looks great!
Thank you for assisting me in locating the extensions I was missing.
Another 65 GTO with the “long” extensions #9417466 as used on this “Custom Wheel Disc” car.
My good friend “Option 382” bought this 1965 New, and it only has 26,311 miles on it.
Without a doubt, one of the very best preserved GTO in existence!
PS, this car still wears its Original Redline Tires. How cool is that!
Chris.
ID:	476926   Click image for larger version
ID:	476927   Click image for larger version
Old 09-20-2019, 04:56 PM
60sstuff's Avatar
Default 5.871 PLUG, WHEEL
Another factory item used to keep small rocks / debris from entering the backside of the wheels and rattling around behind the full “Wheel Disc”.
These black plastic plugs (20 per car) were to be pushed into the four narrow holes on the steel wheels.
Chris.
ID:	520562   Click image for larger version
ID:	520563   Click image for larger version
ID:	520564   Click image for larger version
