Old 12-09-2018, 03:04 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Default Picture request: 67 gto core support to frame bushings
Can someone post up a picture for their core support to frame bushing set up? I think mine are installed wrong. The frame and core support are touching and that doesn’t seem right.
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 12-09-2018, 03:17 PM
younggto younggto is offline
This should help. This car has three thick washers under the shell of the mount whereas my other GTO has two (both 67s); this is to obtain the proper height to get an acceptable door gap.
ID:	499745Click image for larger version
ID:	499746Click image for larger version
Old 12-09-2018, 03:20 PM
sjdiesel's Avatar
Ok great information. Looks like mine is missing two washers on each side.
Sean
1967 GTO
Old 12-09-2018, 03:35 PM
Jeff Hamlin's Avatar
From the service manual;
Note; The large Shims (Washers) will vary car to car to obtain proper panel gap/alignment
Old 12-09-2018, 05:06 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Great information here!
Old 12-10-2018, 01:32 AM
vidguy's Avatar
vidguy vidguy is offline
Here are mine for reference. 67 GTO Driver side.
ID:	499829   Click image for larger version
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 12-12-2018, 04:06 PM
arbys's Avatar
arbys arbys is offline
Great picture angle. Worth 10,000 words.
Old 09-16-2019, 11:00 AM
gassman_67's Avatar
gassman_67 gassman_67 is offline
Default shims
I'm about to re-install my core support in my non a/c 67, thanks for the pics BTW, just curious, my driver side had 3 washers, I can't remember if the sit on the top of the frame, it looks like yours do. The diagram though show 3 washers, but looks like there is something between the frame and the first washer?
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
