Old 12-29-2018, 02:45 PM
Oldsboy20 Oldsboy20 is offline
Default Question about 4 door parts car
Hi, I had some parts swapping questions. I got a 1966 GTO and am looking at a 66 lemans 4 door no post car as a parts car. I know I can use the front clip but I was wondering if I can use the trunk lid, vent windows and frame to use on my GTO? Also will a 4 door power window set up work on a 2 door car? Thanks
Old 12-29-2018, 03:45 PM
Jeff Hamlin's Avatar
OB, Welcome aboard.
As far as the parts swap;
I do believe the vent windows are the same.
Deck lid is Not.
Frame should not be an issue and will fit under your 2DR.
Power window parts may ?
I would think its just a matter of modifying the wire harness but I'm sure others will have further info on that.
Old 12-29-2018, 04:11 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Originally Posted by Jeff Hamlin View Post
OB, Welcome aboard.
Deck lid is Not.
Is not the wheel base longer on a 4 door hardtop or sedan than the 2 door cars?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 12-29-2018, 04:28 PM
Same wheelbase. The '66 or '67 Pontiac A-body four door hardtop frame, while the same wheelbase as same year Pontiac A-body 2 door hardtop/2door Sportcoupe/4 door Sedan frame, there is a slight difference at one of the body bushing mounts. Not a big deal for many restorers when doing a frame swap.
Old 12-29-2018, 04:29 PM
How is the body on that 4 door hardtop?
Production figures for such, 1966 and 1967:
1966: Tempest Custom 10,996 + LeMans 13,897 = 24,893
1967: Tempest Custom 5,483 + LeMans 8,424= 13,907
Old 12-31-2018, 02:13 PM
I bought the car, trunk has rust with couple pin holes. Haven't looked at the floors. Car was sitting in a field for who knows how long.
Old 01-01-2019, 12:48 PM
So whats power plant does or did it have ?
Old 01-01-2019, 05:47 PM
It's got a 326
Old 10-07-2019, 05:26 PM
Scott Thelander's Avatar
whats the update ??
