Old 08-09-2019, 04:59 PM
BN's Avatar
BN BN is offline
Default 70 GTO ac belt
Old 08-09-2019, 05:03 PM
BN's Avatar
BN BN is offline
70 GTO. Had the car three years and want to put ac belt on and see what happens. Everything seems to be there. Problem is I can’t get compressor to get loose enough to get belt on. Do any other bolts need to be loosened other than the two on bracket that go into block?
Old 08-09-2019, 09:45 PM
gtospieg gtospieg is offline
There should be a bolt at the rear of the compressor down low
Old 08-10-2019, 10:15 AM
BN's Avatar
BN BN is offline
Got it, thanks. Could anybody give me the length of the 2 spacers that go between the large aluminum compressor mounting bracket and the engine block? I found somebody had used a lug nut on mine.
Old 08-19-2019, 09:30 AM
HWYSTR455's Avatar
Ames sells the spacers. If they are in question, just replace them.
Old 08-19-2019, 09:33 AM
HWYSTR455's Avatar
A/C belts are a tight fit, just bump it on.
Old 08-19-2019, 06:28 PM
I measured my "spacers" and they appear to be 1"
Old 08-20-2019, 08:01 AM
HWYSTR455's Avatar
Isn't 70 a conversion year for the bracket setups? Some got the 69 type setup, some got the 70-71-72 type setup.
It appears you have the 69 setup, just to say. So the spacers that Ames sells would work.
Would be good to keep that all in mind, in the event you need other parts.
Ransom - Do you know the cutoff years? Were there applications that also used the diff water pump height like on the 'birds? I would think that would impact the spacers or the forward bracket, correct?
